Sub-Zero 695/O Side by Side Refrigerator
Problem for Sub-Zero 695/O Side by Side Refrigerator
Sub-Zero 695s - plastic/rubber fridge door edge is warm
By davesan1 on Mar 27, 2009
Sub-Zero 695s. The rubber and plastic lining inside the fridge door is warm to the touch. This has only started happening recently, but it doesn’t happen all the time. Otherwise, operationally, the fridge and freezer both appear to be working fine.
A previous response said that I need to clean the condenser or that the condenser fan has broken. The documentation supplied with the product gives no help on cleaning/accessing the condenser. I’m familiar with this procedure on more “normal” fridges, but can anybody guide me on this Sub-Zero model, which, of course, has the “guts” on the top, versus below. How do I get in there? Do I need to pull the fridge out from its enclosure or can I get full access from the front?
Clarification Request
Posted by sbringardner on Oct 09, 2009
I had the same problem with the inside lining getting hot (over 100 F) and the service light came on. The heat cracked parts of the inside lining which can not be replaced. Was under warranty and the condensor fan was replaced which was cause for over heating. The only solution for the cracked inside lining was to fill with silicone or a new unit. Since the 695 is discontinued, sub zero offered a new unit at a prorated price. That will cost me about $2700 for a new unit, install and overlay doors. I told Subzero that still sucks because I paid $8000 4 years ago and now I must pay another $2700. Not a very good value considering it's a top of the line unit. I think subzero should have replaced for free considering the problem was under warranty. I may contact lawyer to press the issue.
Same Problem
Apr 06, 2009
-   The Rubber seal on my Sub Zero 695 is also warm to the touch. It has been like this since we bought it, May 2005.-   BETC1060
Solution #1
posted on Mar 27, 2009
Not Rated)
Sea Breeze
Rank: Guru  Refrigerators  Expert
Rating: 90%, 766 votes
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 695/O Side by Side
Questions and Unsolved Problems for Sub-Zero 695/O Side by Side
Do you recommend Sub-Zero 695/O Side by Side Refrigerator?
Answer
Answer
Sub Zero 695 Replugged in after moving and lights came on for an instant with a popping electrical... (More)
Answer
not all the ice is blue, but there is some kind of blue precipitate in the bottom of about 30% of... (More)
Answer
the icemaker in my subzero is making blue ice. how do i fix this?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
