Question about Motorola Mobility H700 Wireless Headset
My headset wil not turn purple after holding it for 5 seconds
I flip the mic and hold it down for 5 seconds but it still does not turn purple i have tried plenty of times to try and get it sorted but it just does not seem to work please help me
  • 7 more comments
  • Chirpee Nov 14, 2007
    WOW!! I tried this and it worked. I had bought the item on Ebay and was just about ready to write the guy and request a refund. Thanks!! I will certainly tag this site in my "favorites."
  • jurq Nov 16, 2007
    i have the same problem, looks like it doesnt react on opening/closing mic
  • fsd1958 Dec 01, 2007
    I 've got a "present" used H700, after charging I triad to pair with my phone but no lack. What can I do to make it work. Thanks.
  • Anonymous Dec 15, 2007
    Same problem - this solution fixed it!
  • shimz Feb 28, 2008
    I can not link my Tmobile Dash to my H700. I had a H700 before and it linked fine, however i can not link the new one.
  • Bizman Feb 28, 2008
    H700 won't go to purple.
  • ladyredd Mar 05, 2008
    i fully charged my headset, but its not flashing. and when i follow the instructions to pair it to my phone it flashes purple but doesn't remain lit or steady
  • saltg Oct 15, 2008
    I have a new H700 and finally started using it only to find i will not work
    it is fully charged (green) light however will not switch on ???
  • normans22 Jan 06, 2009
    Headset is fully charged but won't turn purple
You need to hold down the call button before opening the mic. Once it turns purple immediatly open the mic. If you wait too long to open the mic after it turns purple it will turn blue or just go out.
Posted on Sep 08, 2007
Connection to my phone was intermittent. After finding this solution I confirmed that the pin switch was definitely the problem! Simply pressing on the hinge did not premanently fix my problem, however (disconnected from my phone when I let go), so I cut a thin strip of tape and put it on the pin-side of the boom. Problem solved! Thanks for pointing me in the right direction.
Posted on Nov 29, 2007
This site is awesome. It worked. Thanks
Posted on Nov 19, 2007
Thanks!! I was beginning to think it was broken
Posted on Nov 12, 2007
Thanks ButchJK - I tried almost every other thing - this was the one that did the trick for me...
Posted on Oct 14, 2007
Look very closely at the hinge on the boom. There is a very small pin-switch that glides in a groove when the boom is opened and closed. Sometimes "slop" will develop in the hinge and the pin-switch won't get pushed in enough to register that the boom is open. Light pressure applied by squeezing the hinge to push in the pin-switch should work. --For some reason pairing mode is much more picky than regular talk mode.
Posted on Oct 09, 2007
Wow, thanks I appreciate the help
Posted on Sep 25, 2007
THANK YOU!!! IT WORKED.
Posted on Sep 18, 2007
Thanks 'Guest Oct 09 2007' for alerting me to the pin switch problem.
I bought a new H700 2 days ago and found that the H700 could not be turned off by closing the flip. I returned it 1 day ago and the dealer gave me a new replacement.
Same problem. After reading your post I found the pin switch and it is very loose in its mount. It looks like Motorola has quality control problems with the H700.
I will return it to the dealer and attempt to get it replaced again. I like the H700 but if the pin switch problem is endemic, perhaps I should look for a refund.
Disappointing, because in other respects this seems to be a fine headset.
Posted on Feb 22, 2008
SOURCE:
I have a bluetooth blueant n15417 and cannot put in discovery mode
To put the device into pair mode, hold the green button down for 5 seconds, after 5 seconds while still holding the green button release the mic arm. The device should then be in pair mode, if not the pair list may have become filled. To clear that hold down the vol + button for 5 seconds and release the mic arm. If you don't get any loud sound, power off the unit and hold the red button for 5 seconds while releasing the arm. Eventually you will get a red/blue flash telling you it is in pair mode (or what you call discoverable mode, which technically is referring to the phone). At that point go to the bluetooth menu, search/scan for devices/add a new device and enter the pin code 0000 if prompted.
Rylan
Dec 10, 2010 | Blueant SuperTooth Light Wireless Headset
I can not figure out how to put in discovery mode when turning on
close the mic and hold down the button until it becomes purple. Open the mic and it should stay steady lit purple. Then you can pair it with your phone. I found the manual online because I had lost mine as well. Also, make sure any old phone you were using it with is off so it does not connect with that one. Good luck!
Feb 09, 2009 | Motorola Mobility H700 Wireless Headset
How do you reset it?
Turn the headset off (flip the boom in) then hold down the talk botton. The indicator should turn solid purple. Keep holding the the talk button and turn the headset on (flip the boom outward) and then it should stay soild purple and ready to pair with your phone.
Good luck.
Jul 19, 2008 | Motorola Mobility H700 Wireless Headset
Pairing
With the microphone closed, push in the call button. It should turn purple within a second or two. When it does release it and as quick as possible flip open the microphone. The light should stay purple and it is now in "pairing mode"
Jul 10, 2008 | Motorola Mobility H700 Wireless Headset
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Purple light wont stay lit for pairing
Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
Mar 18, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 Headset
close the ear peice and hold the button down till it blinks then open the ear piece.
Nov 11, 2007 | Motorola Mobility H700 Wireless Headset
Connection problem
noavatar_s.png By nonexpert_s.gif Guest
Rank: Not rated
Rating: 0%, 0 votes
First, turn on your bluetooth on your phone.
Flip the boom mic on your H700 and hold down the call button for 5 seconds.
The indicator light should be purple. That means it is in pairing mode.
Then using your phone, attempt to connect to your H700.
It'll ask for a passkey. The default passkey is 0000.
Nov 08, 2007 | Motorola Mobility H700 Wireless Headset
Help
Rank: Not rated
Rating: 0%, 0 votes
Nov 07, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
932 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
