Question about Motorola Mobility RAZR V3
Dropped it and screen went blank
I had the razr in my pocket when i jumped for some reason. then my phone, since it was clipped on to my pants, fell off and hit the cement pretty hard. the only problem with it is that the inside or main screen went blank.
    Brigadier General:
  • 7,752 Answers
Take the phone and have them replaced the lcd or flexcable
Posted on Feb 24, 2008
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
Dropped my iphone 3G, screen went black with some vertical lines. itunes still recognizes the device, i can still play music (using a speaker/charging cradle remote control)I can still hear SMS alert and...
It just happened to my this afternoon. My iphone dropped out of my pants pocket to the ground. The front lcd of the iphone hit the ground and it when blank/black. My iphone happened just like what you've described. I got my fixed. I opened it up and found the connector of the lcd was loose. I securely reconnected it and voila!!!! It works again like a charm! Goodluck to you all who has the same problem.
Dec 17, 2009 | Apple iPhone 3G
I also have a Sony Ericsson K850I and dropped in the water.
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Jul 04, 2009 | Sony Ericsson K850i Mobile Phone
Phone is working but Screen doesn't work its blank
I have a similar issue...left side hinge pin came out...found it in my pocket and attempted to put it in place and then the screen went blank...no luck...but I was able to take the motorola phone toola and retrieve the data, names, etc and move to another motorrola phone I have. A few days later I found a small wire clip thing that must ground or contact something in the hinge...no luck yet fixing it. Help
Oct 12, 2008 | Motorola Mobility RAZR V3
Blank screen
you will need to take the phone and have it fully service and replaced the lcd
Sep 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Screen broken
You need to take the LCd out and replaced it.
- the flexcable on the phone needs to be replaced.
Jun 09, 2008 | Motorola Mobility RAZR V3
My screen is black
did you drop your phone
well if you did you jarred the screen loose from connector
if you didnt drop it
then make sure phone is on and do what they call a cold boot
pull the battery out remove sim blow on sim and place back in phone
May 26, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Blank screen
this happens either when u r razr was dropped or have gotten wet...If it fell u need to remove the four screws on the screen and pry the cover off with a possibly thin knife.The flex cable is located at the top left hand side of the screen. you need to take this off and reseat it again.try powering on the phone before u close it back again to ensure that it works.If this doesn't work either your screen or flex cable is gone, then u need to check a phone repair shop.you need either a t6 or a t4 screw driver set to remove the four screws located under the the 4 rubber fillers on the inner screen.
sam !
Feb 19, 2008 | Motorola Mobility RAZR V3
External screen blank on razr v3
razr phones are sensitive phones, check service center near your area or check manufacturer for repair.
Sep 26, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3 Logo
83 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
