Question about Olympus Stylus 600 Digital Camera
Dropped in water
My beautiful Olympus stylus 600 was dropped into a small puddle of water for three seconds and appears to have absorbed a small amount of condensation under the LCD screen. The camera worked slightly right after the incident but has since not even worked to turn on or off. All the water was cleared out of the battery pack and memory card (not that there was much) so the only visible problem is the small beads of condensation in the lower left-hand corner of the LCD. Please tell me there's hope for my birthday present. :(
Just go to the place you bought it and ask to get it fixed
Posted on Jan 15, 2008
I put a brand new fully charged batterie in my olympus stylus 600 and it still won't power on, any suggestions as to my?
Without specialised test equipment, diagnosing faults on totally dead electronic devices is near impossible. Even with the right tools it can be difficult.
Unfortunately your camera is effectively now scrap: any kind of professional attention will cost more than the camera is worth and spare parts may not even be available. Your camera was designed to last around five years, so all that can be said is that it has failed a bit earlier than it should have. If your camera has ever been wet or has been covered in condensation (as may happen when moving from the cold outdoors to a warm house) or has ever been dropped then it will have shortened the lifespan.
If you are confident that your camera has never been wet/dropped then it may be worth complaining to Olympus. They may offer to examine the camera but will usually warn that if found to have been liquid/impact damaged then they will charge a fee and return the camera unrepaired to you. Otherwise they may choose to repair it (subject to spares availability) or may offer a discount on a replacement.
Sep 11, 2010 | Olympus Stylus 600 Digital Camera
My olympus 1040 was dropped in water for a few seconds,i dried it out and now it will turn on but screen is blank,is there anything i can do or is it only fit for the bin..........
Solution: The most important thing to remember if your digital camera should be partially or fully submerged in water is to act quickly. Once your camera is out of the water, avoid the urge to turn the camera on to see if it works and instead remove the batteries immediately to prevent shorting any of the internal electrical components. Remove your memory card also, otherwise you may lose the pictures you’ve already taken and saved to the card.
Leaving the battery and memory card compartments open, dab away any excess water with a dry cloth or paper towel. Then, use a household hairdryer set to the lowest heat or no-heat setting and blow dry the camera for 10 to 15 minutes.
Although the outside of the camera may be dry, it’s what’s on the inside that counts. If any moisture is left within the camera, it may, over time, grow mold, which can interfere with the camera’s operation. If the camera was dropped into a chlorinated swimming pool or a saltwater lake, your camera’s components may suffer corrosion over time, and your camera will eventually stop working.
To help draw moisture out of the camera, pack your camera in a bowl filled with silica gel (the packets of small transparent beads often found in various foods, electronics, and clothing packages) or uncooked rice. Both materials can absorb and hold excess water that may be left in your camera. Leave your camera to dry for at least 24 to 48 hours. Once you are certain that your camera has completely dried out, insert fully charged batteries and press the Power button. With any luck, your camera will function properly. If not, you may try contacting a camera repair company to ask advice or inquire about repair options.
Jun 26, 2010 | Olympus Stylus / mju 1040 Digital Camera
Dropped my Olympus Stylus 1050 SW... now it wont turn on!
make sure the battery is charged and if it is and u r still having this problem try pluging it in a pc to see if your camera still works if it is maybe the lenz is messed up and if thats the case i cant help u with that
Sep 21, 2009 | Olympus Stylus / mju 1050 SW Digital...
My olmpus stylus 600 digital camera takes poor night photos
Dear when turned on the Night Mode in any digital camera, You must use the tripod. Try it, i hope ur problem will be solved.
Jun 13, 2009 | Olympus Stylus 600 Digital Camera
Computer no longer recognizing olympus stylus 600 camera
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
For MAC:
Olympus Master 2.11:
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
( Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version).
Feb 28, 2009 | Olympus Stylus 600 Digital Camera
Pixel problem, all pictures taken have poor pixel resolution
It sounds like you set the file settings to a small file size - perhaps in order to get more photos on a single memory card. You need to change the setting to the largest file size possible, at the highest quality. The steps for this will be in your manual. If you need detailed instructions and don't have your manual, let me know and I'll lookup your manual online.
Dec 30, 2008 | Olympus Stylus 600 Digital Camera
Camera dropped in water
You will need to contact Olympus Customer Service to discuss repair options and pricing. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 26, 2008 | Olympus FE-220 Digital Camera
Olympus Stylus 600/Digital 600 6.0 megapixel
This camera can be very picky when it comes to the front lens cover... It's not a simple mechanism and has many small parts and gears involved. If the lens cover is dislodged it won't work smoothly, and if the case is dented it will not be able to move properly and this can cause lens problems.
If the lens was out when the camera was dropped, then it's possible the lens was damaged and not the lens cover. Sometimes you can tear down the lens, clean it and rebuild it and it will work smoothly again, sometimes this doesn't work and the lens needs to be replaced.
If you're comfortable opening the camera, first check out the lens with the front body section removed so nothing is blocking the lens cover. Does it work properly now? If not, then expect lens damage to be the issue.
We are an AFFORDABLE digital camera repair shop... if we can assist you with parts or do the repair please let us know. (google: darntoothysam)
Hopefully this is of some help. Even if you don't use our services please feel free to let me know if you need more assistance.
Good luck from Darntoothysam com
Oct 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Olympus stylus 600
look for a small pinhole on the camera body. insert a pin with power on to reset the camera
May 25, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Manual for olympus digital 600 camera
Heres the link; Enjoy your camera:)
Apr 15, 2007 | Olympus Stylus 600 Digital Camera
Olympus Stylus 600 Digital Camera Logo
49 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
