Question about RCA 32V420T 32" TV
52" RCA menu
The menu screen on this tv continues to popup irratically and we cannot find out how to correct this...the screen also freezes and once the ok button is pushed on the remote the picture starts up again...i have looked in the troubleshooting guide and there is nothing on this! would somebody please help to rid this because it is become annoying!! thank you
    Genius:
  • 1,694 Answers
1)Please clarify model # 2)Try reset==unplug AC cord for a few minutes, a few hours or overnight,if need be. 3)let me know if you need more help.T.
Posted on Oct 09, 2007
SOURCE:
I have a 52" RCA
Make sure you are connected to correct cable IF connector,Go to Menu and see if you are on Cable or Air.Then Do AutoProgramming.
Feb 17, 2011 | RCA HD61W140 61 in. Rear Projection...
Menu screen pops on and off rca 52 wide screen hd
Dirty contact switches, clean all the contacts on front of TV with contact cleaner.
May 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca hd '52" tv has a bow in it & colors dont line up
Blowed Fuse FL231 will be on right handside of FBT flyback Transfomer there is 3 of them in a Roll small brown looking caps But they are Fuses it will be the one in the Middle Located on your Deflection Board which is the Bottom left hand side Board. www.Partstore.com for Fuse
Dec 21, 2009 | RCA HD52W59 HDTV Projection Television
My rca 52'' flat screen tv
It sounds like your TV needs to be aligned. There should be a menu item in your setup menu called "Alignment". Once you choose this the system will either automatically align itself, or the screen will display a graphic that will allow you to align the guns manually. Normally you will move either up or down or side to side until 2 separate lines look like one.
Jul 14, 2009 | Televison & Video
How do you use the pip/swap buttons....
Go to rca.com , click tv then click support, drop menu size then drop menu model #and you can download user guide
Jan 11, 2009 | RCA D52W19 52" Rear Projection Television
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 in rear projection... start up menu always on
finich seting up ...go through the setup menu. and pushing ok instead of clear. if it continue this indicate the main ac is being interupted.. do you unplug it at night? or just power it down.
Dec 15, 2007 | RCA HD52W58 52" TV
Projects picture bigger than screen..
This must be a duplicate, and since I'm not sure which one you'll be checking back with: Go into the menu and select picture settings and then advanced picture settings. I'm not sure on that model that you can manually change the aspect ratio from zoom to 16:9 or 4:3 ect... But select Auto Format and the TV will pre-select the correct format for viewing..... Any questions just let me know. Bill
Jun 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 32V420T 32" TV Logo
63 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
