Question about Alpine CDE-9843 CD Player
Cd will not eject
Face drops down and "open" displayed on screen.have killed power and pressed reset but not having any effect
    Genius:
  • 1,153 Answers
You killed power meaning? Did you disconnect battery, for atleast 15min? If you cannot get out this way you will have to take out car and open up top and manually take out.
Posted on Sep 25, 2007
SOURCE:
Cd will not eject
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Finally what to do is try pick up your macbook tilt the macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE CD DRIVE (Use it at your own risk), so only use it as a last resort. Get a thin piece of plastic (or credit card) and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the CD out. Hope it helps.
May 29, 2012 | Apple Computers & Internet
I have a jvc am/fm cd player kds-30 it has no eject button anywhere and i can not figure out how to eject the cd
The eject button is just above the JVC logo on the display panel.
When you press eject and if it displays "NO EJECT", then it is locked. Press and hold CD and Power (ATT) for more than two seconds.
Feb 09, 2012 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-AVX1. The head unit will not "turn on" when the power button is pushed. The display just stays off. The face lights up when you press the eject button and opens up and you are able to feed...
is this a headunit you have just installed? if not then I am not sure, but if it is, try swapping the red and yellow wires over. One should have permanent live, the other should be switchable. (unless you want the headunit to stay on when the ignition is off, in which case put them both to a permenant live feed.)
Hope this helps.
May 09, 2011 | JVC KD-AVX1 Car DVD Player
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Face plate won't open far enough to insert a CD
try to hit slowly the faceplate in the left side until its open
Mar 08, 2008 | Pioneer DEH-P80MP CD Player
Drop down face problem
try resetting it by pressing the little button on the front of the face
Nov 29, 2007 | Dual XDMR-7700 CD Player
CD do not eject
I have the same prob with mine right now and thats why I came here was to find the manual. In the manual it states that that when something like this happens you need to hold two buttons for a few seconds and what it does is it resets the cpu in the deck. I had to do it before and yes I was kind of leary of the solution also but IT WORKED!! Now I'll have to dig before posting this otherwise I didnt just create a common solution I talked about it. Ok while holding power/ATT press eject for more than two seconds, and it says careful not to drop the cd~~~DAAA Or to reset the unit: While holding SEL (select) press power/ATT for more than two seconds and that will reset the unit to factory defaults. And this was actually from my owners manual of which I found...
May 26, 2006 | Jwin JCCD200 CD Player
Alpine CDE-9843 CD Player Logo
79 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
