Question about RCA P61830BL 61" Rear Projection Television
Projection TV - RCA P61830BL
My TV will turn on, but there is no video and the menus work fine. The audio also works. Any suggestions.
  • jc0028490 Sep 01, 2008
    I have the exact same issue.
Hello, I have a Tv RCA P61830BL, I need a new convergence board but cannot find out where I can purchase one from. Can you help?
Posted on Jul 21, 2008
6ya staff
SOURCE:
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
vertical output IC is most likely defective or bad solder.
Jan 30, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Projection TV not working properly
All I need to know is how to shrink the picture!
Dec 21, 2008 | RCA P61830BL 61" Rear Projection...
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Rear projection tv broke
try resoldering the vertical output IC. This is a common problem the tubes blank out but sound and on screen displays still work 90% of the time its the solder connections on the vertical IC that causes it.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
No video problem
Wha is the chassis number for your set? It should be located on the rear of your setnext to the model number it will be an ATC number.
Feb 23, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Dec 21, 2007 | Televison & Video
Toshbia Projection 50''
A few problems come to mind. The high voltage block took a dump and opened up. The filiment supply from the HV sweep has cold solder connections on the Printed circuit board. Another problem is the most common of all could be a vertical sweep falure like the vertical output IC or the b+ going to the chip or maybe even a bad yolk connection on the solder side. Good luck
Apr 28, 2006 | RCA P61830BL 61" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
