Question about Sanyo DS24205 24" TV
No Sound, perfect picture but no sound
My television has no sound. I was watching it one evening and there was suddenly no sound. If I connect the DVD player, the cable, or cable box there is still no sound. My other televisions connected to cable still work fine. Someone told me to check to make sure the speakers were turned on in the "Audio Setup" menu; I can't find such a menu. Help Ron
Go to the audio menu setup then find the sub menu speaker after that you will see some command indicates if you want to on or off the speaker, choose the on command to be able to hear the sound in your television from your dvd player.
Posted on Aug 26, 2007
  • nho2 Aug 26, 2007
    if audio menu is not found the practical way is to check weather the speaker is good or bad. if it is good, suspect the defective audio amplifier of your television set. replace it to solve your problem.
32 inch LCD TV samsung series 5
If there is sound, no doubt, its signal input is OK. The problem must be to your Tv itself. If the LVDS cable, the cable that connects between the T'Con board and LCD panel have a loose contact, this type of faultcan occur. Re-seat this cable once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Hundred Thousand viewers cannot be wrong.
May 05, 2013 | Televison & Video
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
Oct 16, 2012 | Digihome LCD TV
While watching the TV the picture suddenly went out - still have sound. Turning the TV off and on again does not help - the POLAROID Logo displays, but when the station connects - still no picture
possibly external power supply faulty under load it may fail these power supplies ofen have capacitor failure open the power supply to check for leaking/bulging/swollen capacitor is around 2000uf rated at 12v
Apr 28, 2009 | Polaroid FLM-2011 Television
All of a sudden the sound on our LCD tv has gone. We've checked all the cables are in correctly and even though the picture is perfect we have no sound. SAMSUNG SYNCMASTER 741MP
Connect the cable directly (bypassing the cablebox)and
set menu to cable channels ,
tune to channel 3 or such and do you have sound now.
if not the amp is out , you might just consider using external speakers as they will sound better anyway.
Feb 25, 2008 | Televison & Video
RCA D52W17 Rear Projection HDTV......No Sound
in the sound settings is the amplifer set to external or internal.
if thats not the problem.. the audio amp chip might be out. to repair this a technician usally replaces what is know as the small signal board.
Jan 10, 2008 | RCA D52W19 52" Rear Projection Television
Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Sep 27, 2007 | Sylvania 6427TE 27" TV
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
Sound but no picture
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Nov 17, 2006 | Akai LCT2060 Television
Sanyo DS24205 24" TV Logo
309 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
