Question about Maytag Neptune MAH5500B Front Load Washer
Flood Damage? Our basement was just flooded, with appoximately 11 inches of water. We put the fan on the back of the washer to help dry it out for a couple of days, but that didn't seem to help. It keeps giving us a code of DO when we hit the start button. The Neptune Dryer is fine and works. Please Help.
  • 725 Answers
Do error is a Door open error code.. but if it is closed it could be a faulty door lock or a control.. check to see if you can open the door..hope this helps let me know.
Posted on Aug 26, 2007
How to dry out basement after flood on my own
run fans and a dehumidifier
Sep 20, 2018 | Dryers
Why wont the motor on a top load roper washer work after a flood
If the motor was submerged in water it's probably shot. They aren't made to function during and after exposure to water.
May 20, 2014 | Roper RAS8445KQ Top Load Washer
Will not spin or agitate
did the washer cause the flood? you could have got water into the motor if it was above a few inches deep. do you hear the motor working, and no agitator movement? will it fill ? or is it just dead?
Nov 10, 2013 | GE Profile WPRE6100G Top Load Washer
Basement got about 4 inches of water. Washer will turn on, but does not function.
Sounds like the Motor Controller on the left side of this Pic may be the issue. The Drain Pump/Pressure switch is on the left side of the Pic. I feel the drain pump may not work after the basement flood. You can get into Service Mode and try to turn it on from the Console once the machine is dried out.
Aug 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
No heat..we had a basement flood and dryer won't heat up.
If your dryer was under water, even if only a few inches, then the electrical parts inside it will need to dry out before you even attempt to use it. Chances are, you will have to have it serviced now or replaced completely.
Douglas
Jun 25, 2010 | Dryers
F/ll blinking is there a switch in case of flood?
If you had a flood and any water got into bottom of machine, you have probably shorted out a motor control board. These board are either in the lower back right or front left corner bottom. A qualified service tech should be called to do this repair.
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
Refrigerator was in the basement with 6" of water....
The electric parts that got wet will need to be dried out. Try putting a flood light etc. shining on the bottom for a few days to see if it will dry it out, then turn it back on and listen for a click from the compressor relay as the compressor tries to start. Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
147 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
