Elan E-948-DB / E-948-DW / E-948-DS Electric Single Oven Logo
Posted on Aug 25, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Slow warm up
My oven takes more than one hour to reach 350 degrees. What shall I do to speed thing up?Irrespective of the setting
  • petrich Aug 27, 2007
    Thanks for the follow-up. We are getting an electrician.
    Is it possible that 120 volts is unavailable in a large American apartment building since 240 is the standard in Europe but not America ?
    Additional question: You said that the thermostat was at the rear, but I don't see anything like that. Could it be behind the temperature control on the right ?
    Last, One of the oven lights is out. It is a Phillips S4J 25 watt, 125 volt, screw base; 300 degrees C H.D.. None of the bulb sites seem to list that bulb. Any suggestions?
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Aug 26, 2007
Anonymous
Master
Level 3:
Answers
725
Questions
Helped
406874
Points
1785
Hi petrich let me know if you had your voltage to the oven checked. is must be the problem to have two ovens slow to heat up... let me know..krazytech
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 • Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
1helpful
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 • Ovens
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
1helpful
Maytag MER5775QAS
Could be a couple things. If your machine is actually failing either a control board or an oven sensor.
Also measuring the temperature can only be done by a tech unless you have a special tool. Oven thermometers are inaccurate. Plus most ranges should vary temp between 50-75 degrees unless has a feature or the more recent ones keep it between 15-25 degrees.
Try the biscuit test, buy some biscuit, brand not important, i just say pillsbury. Cook exactly as recommended on package. If results are a little overcooked or a bit undercook try a feature called Adjusting the oven temperature or Calibrating the oven. This can be done by following the instructions in your book.
Maytag.com click support click manuals put in model MER5775QA (notice i took off your models S) open the Use guide, page 14
May 01, 2008 • Ovens
Top Elan Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Elan Oven Expert? Answer questions, earn points and help others
