Question about Quartet gbc 2230S Shredder
Door light stays on...
Please help...will not start for now.
  • 30 Answers
The door light is controled by a switch that is mounted inside the body of the shredder and is operated by a bayonet type of prong that is attached to the door itself. The most likely causes are: the bayonet attached to the door has come off and the switch never is closed. The other possible is that the switch which is adjustable in most units has gone out of adjustment. If you look at the door and follow the bayonet's path, you will see a slit in the front of the unit the the bayonet fits into and if you look under the slit the screws that adjust the switch, one of which is in a slotted opening. Loosen the screw and pull the screw toward the front of the machine and that shouls cause the switch to be activated when the door is closed. The other possibility is that the switch is bad or the circuit board that the switch connects with is bad, and that's going to take the services of a qualified technician, and that means money. However, the simplest is ususally the switch. Let me know if this helps. Aloha, Bill Monroe
Posted on Sep 29, 2007
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
... locking when using key fob, only from the inside via the lock on the drivers door key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ... > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
How do I find out which fuse is for my dash board lights when I dont have my manual?
The door ajar light doens't have a separate fuse. But you can probably fix the problem in 15 minutes:
  1. Make sure all doors and trunk close tightly. Lean hard against each door, starting with the driver's, because it is the most likely since it gets the most use. Watch the light. If it goes out, you're halfway there - you've located the problem door.
  2. Squirt some WD-40 into each door's switch. They may be located near the hinge, or near the latch. Press the button repeatedly and then wipe it off. That may fix the problem.
  3. Next, it could be the alignment of the door and strike plate on the jamb. Adjust the latter until the light goes out.
If that doesn't do it:
  1. Dont worry about the battery going dead from the indicator light staying on - it draws too little current. But if a dome light (or trunk light) stays on, it will drain the battery in a number of hours.
  2. You didn't say whether the dome light stayed on. If so, or if you have any other information, please post it and I'll try to help you determine the next steps.
Has this helped ?
- Malcolm
Feb 21, 2015 | 2002 Kia Spectra
My door open light stays on as do interior lights
Sounds like one of the door triggers has continuity to earth,(Shorted) Test them all with a multi meter.
Cheers CeeBee
Oct 20, 2009 | 1999 Chrysler Concorde
Door light and Interior light comes on-01 PT Cruiser
Hey there, I'm the guy with the same type problem that posted above you. You can turn off the dome light by the switch on the turn signal stalk (lever). Just rotate it to the "off" position. The interior lights on the dash and console will be dim, but you will barely be able to see the speed etc. Thats what I do.
As for the dome light staying on. Sounds like your problem is in the switch itself. I would start at the one that was just adjusted. with the door open you can flip the ting switch (the latch that closes the door) with a screwdriver and it will simulate the door being closed so you can fool with it while open.
Sounds like it could use some adjustment as it's not closing completely. It's 3 torx screws. loosen them and move the switch around a bit (you can get a little play) as the front door switch is in the latch itself. Hope this helps! and of course, if somone else has ideas please feel free to send to me, as I can't find where my switch is grounding. I'm guessing the BCM but can't find where. It's sad too, because I'm starting to really hate this car. Overheating, transmission leaks, now this...
Jul 03, 2009 | 2001 Chrysler PT Cruiser
Door latch
check the door jamb switch it would cause the light to stay on
Jun 30, 2009 | Dodge Charger Cars & Trucks
Airbag light stays on
take a look at
They're working in Airbag-Simulators and Occupancy Sensor-Simulators.
Mar 12, 2009 | 2002 Volkswagen Beetle Turbo S
Sharp R-1750 Microwave
the door switches need adjusting. remove casing and adjust door switches
Jan 25, 2009 | Sharp R-1750 Microwave Oven
Radio in 05 Malibu Maxx LS
The reason the radio is staying on is the retained accessory power not shutting down when the driver's door is opened. You can verify this by opening the door with the key on, if the door ajar light on the instrument panel does not light up the switch in the door latch is defective. You will need to replace the door latch.
Aug 20, 2008 | 2005 Chevrolet Malibu Maxx
Please help , tell me why door is locked, on h 2 kenmore washer,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Quartet gbc 2230S Shredder Logo
270 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
