Question about Onkyo TX-DS575 Receiver
Remote control my remote control does not work the red light flashes when i press it sends out but no response from the receiver can you help thank you jackie
  • 4 more comments
  • Anonymous Nov 08, 2007
    I'm having the same problem. I have verified my remote works as I took the remote to my neighbor's house and it worked on his Onkyo, but the remote will not operate my unit. His remote does not operate my Receiver, either. Could my remote reader have gone bad? I've tried unplugging the unit, that doesn't work. Is there a way to 're-boot' a machine. It's not worth sending in for repair since it's so heavy and postage would be very high. The receiver hasn't been used much, so I'm very disappointed given the cost of this unit. Any help is appreciated.
  • pclausen Dec 08, 2007
    I am having the exact same problem. It's as if the IR remote sensor on the receiver has just stopped working. Has anyone found a way to fix this without sending in for repairs? Based on equivalent replacement cost vs. repair cost, getting it fixed doesn't make sense.
    Thanks!
  • run_exe Dec 19, 2007
    I have the same problem. The remote only works intermittently, usually when the unit is first powered on. I bought a new remote from replacementremotes.com (it is cheesy, but only $20 vs. $100 for an exact replacement). The behavior with that remote is exactly the same as with the original. I was hoping to find a solution on the web, but no luck so far.
    The next steps I may try are:
    1. Look in the manual for the location of the sensor (note, it is most likely not where the blinking light is) and clean the plastic in front of it.
    2. Open the case and see if there is dust in front of the sensor. If so, blow it out with canned air.
    3. Try to find and install a replacement sensor, IF it looks easy, and IF I can determine the component number.
  • Anonymous Dec 29, 2007
    Well, let me join the club: exactly the same here! I´m 100% it´s not the remote. I also doubt very much this is a dust matter, as sometimes it starts working again suddenly after 15 min. or so. However when doing fine, it might suddenly drop out! Sometimes it helps to pull the plug from the wall outlet for a while: it might work as a sort of reset. One day this helps (temporarely!!), the other it doesn´t at all. This situation is lasting for about a year now. Not considering having it repaired (if possible at all!?), rather buying something else. For the rest this set is (almost) perfect fot my needs. Really hope someone turns up with help!
  • run_exe Jan 03, 2008
    I looked at the service manual suggested by the guest poster (thanks). It doesn't have anything specifically about testing the IR sensor, but it does have circuit diagrams and shows how to take the unit apart. The IR sensor appears to be directly connected to a microprocessor chip, although there are two capacitors also connected to it. It seems that the problem could only arise from one of three things: bad sensor, bad capacitors, bad microprocessor chip. I am going to take the unit apart and see if I can figure out which one it is.
  • imoveritru Mar 03, 2008
    I have the same problem. My remote worked fine until last night. I hope someone figures this out.
    I did find instructions to reset the remote to the base settings. It didn't help.
Hi! Just found out you can download a service manual for the 575X (which may be almost equivalent?) here: http://fileshare.eshop.bg/downloadsm/26069/ONKYO_TXDS575X.html
Haven´t had time to search yet, but maybe one of us can find a hint there.......?
Posted on Dec 29, 2007
  • 752 Answers
Have you pressed the Mode Audio button on the left above the circle? This tells the remote you want to control the reciever.
Posted on Dec 18, 2007
Onkyo tx ds777 remote does not working
If battery replacement does not work, your remote control probably has failed.
Dec 20, 2017 | Onkyo Audio Players & Recorders
I have a videocon vitaair AC . The remote control function is not functioning. The AC is not receiving any signals from the remote. Remote control has new batteries and display working.kindly help.
you can check if the remote is transmitting by looking at the end of the remote where the little bulb is that you point at the air con unit through a smartphone camera and press each button, if the light flashes the remote infra red transmitter is sending. your mobole camera can pick up light in the part of the spectrum your eyes cannot and displays as a flash. it will at least let you know if the problem is the remote transmitter or the units receiver
Mar 02, 2017 | Televison & Video
Remote does not work. I have changed batteries twice - yet remote has red light with no response from the TV. Thanks
You can test the remote control using a camera to see if the remote is transmitting the IR signal. Place the remote control in front of camera and press any button, once you press the buttons you should see the LED on the remote emitting a light but that is only visible on the camera. If no light is visible, then the remote control is defective.. If light is light is present, then is IR receiver on the TV is defective.
Let me know if you require further assistance.
Aug 24, 2015 | Vizio VA26L 26 in. LCD HDTV
Hi. my original remote for my onkyo tx ds575 all of a sudden is not working anymore. the red light on the remore still lights up when i press a button but the receiver is not picking it up. hopefully you...
The red light on the remote just means the battery is good and the remote is responding when you press a button. It doesn't mean the control is actually sending out a signal. Many retail stores have a tester that will tell you if the remote is transmitting. Another possibility is that the remote sensor in the receiver has gone bad, and that the remote is fine. A universal remote (One-4-All URC6131, for example) that can work home theater receivers can be used to test the receiver. It may not work all the functions, but if it turns the receiver on and off you'll know the remote is at fault and not the receiver. Then you'll be able to replace the remote or have the receiver serviced as needed.
Mar 21, 2011 | Onkyo TX-DS575 Receiver
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
Rca universal remote not working
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 24, 2008 | RCA Universal Remote Control
No codes work :(
Emerson codes: 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
You can find the remote control codes for different brands of devices from
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing the following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 13, 2008 | One For All URC4220 Remote Control
Codes for philips universal remote
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Cheers!
IrishDruid
Apr 13, 2008 | Universal Remote Control Hampton Bay...
Onkyo TX-DS575 Receiver Logo
219 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
