Question about Dell A940 All-In-One InkJet Printer
Printer Stopped Working - Error 126
I have had my printer for about three years. It has worked great, until a week ago. When I sent a print job to my Dell A940, I received the following message: Cannot Load Library "DLBAPRP.DLL" Error 126 I deleted the printer, and reinstalled with the CD driver. Same thing. I called Dell Support two days ago, spent three hours on the phone. Dell also deleted and reinstalled the printer. The result: Dell A940 printer does not work anymore on my Inspiron 8600. Help!
  • 256 Answers
Re: Printer Stopped Working - Error 126
You need to right click on the 'My Computer' option and select 'Properties'.
From the 'System Properties' window you need to select 'Advanced' tab and select 'Environment Variables'.
You need to select the 'Path' option under 'System variables' and select 'Edit'.
In the variable value text box you need to type "SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\wbe".
Finally press the 'Ok' button.
Get more information to fix Printer Error 126 . Hope this information helps you.
Posted on Aug 04, 2011
  • 69 Answers
Here is a link to microsoft they have a step by step process to try and troubleshoot your problem:
Posted on Aug 26, 2007
0 characters
3 Points
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Printers & Copiers
I have had this printer for over a year and it has worked flawlessly until about 3 weeks ago and now it takes about 2 minutes after I click on print for the printer to activate. Any suggestions?
If your X3550 prints OK when it does start, perhaps the selection for printing immediately when receiving a print job has been changed to printing after entire print job has spooled.
This selection can usually be toggled between these two choices.
Jan 14, 2010 | Lexmark X3550 All-In-One Printer
Two dell 1720dn printers with two different problems.
Call Dell and get the drum count reset instructions. They should tell people this info...but neglect to. :P
Feb 24, 2009 | Dell 1720dn Laser Printer
Check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Stop'd recognising CISS cartridge, just searches, won't print anymore
How was it fixed (don't know)?
Systems personnel fixed it.
I'm only the end user!
Nov 06, 2008 | Epson Stylus R265 InkJet Photo Printer
Xerox Phaser 6100 will not print
Yeah you need to replace that imaging and transfer units for it to print. That has a counter on it and once it comes up with that message it will not print anything.
NOW THE WARANING. Once you replace the unit. Everything you have sent is in the memory and will print out.
What you will want to do is once it starts printing, continue to cancel the jobs until they are all out of memory. Believe me, the jobs are there....
Oct 09, 2008 | Xerox Phaser 6100/BD Laser Printer
Printer not printing a red light comes on.
first u check the feed roll component.. and remove than refix a connections.. then may be its working.
Aug 05, 2008 | HP LaserJet 2100 Printer
Lexmark Optra 312L Black & White Laser Printer will not print properly
it's toast...
get another brand, and recycle that one responsibly.
May 21, 2008 | Lexmark Optra E312L Laser Printer
Printer not receiving jobs
Hi Mark, first of all,You need to check ports on Your PC ,if this printer is networked.Second, try to set sleep or Energy saver mode on printer to highest possible time.To do that,just press "Menu" key on printer control panel and go through menu to find sleep mode.And maybe best solution is to upgrade firmware on your respectable machine.For that, You need :Compact Flash card type 1,Card reader,and firmware.Obtain or download firmware files or informations about that from Kyocera web site or from Kyocera service partner in Your country. Copy unzipped files to CF card(you need to format CF card on printer -Read user manual )Switch off printer.Push card in CF Card Slot in printer.switch on printer and wait till all light flashing on printer control panel.Switch off printer and remove CF card.You can contact me if you have any problems about that machine.BR
Nov 28, 2007 | Printers & Copiers
Sounds like a software issue not the prnter. Try uninstalling adobe if this is wat the program is and reinstalling.
Aug 22, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Dell A940 All-In-One InkJet Printer Logo
1,577 people viewed this question
Top Dell Printers & Copiers Experts
Prashant  Sharma
Prashant Sharma
Rick Johnson
Rick Johnson
Level 1 Expert
Are you a Dell Printer and Copier Expert? Answer questions, earn points and help others
