I couldn't tell if the water was draining. When you advance the cycle to spin the first thing it should do is drain the water. This will happen for a short time before it spins. If it is not draining then you need to check the drain pump for blockages( and pipes) the machine will not spin with water in it! If it is draining but not spinning then it is probably a faulty lid switch and needs replacing. There are a couple of other causes but they will usually create a fault code which you don't seem to have. Most likely blocked or faulty drain pump.
SOURCE: Elba Washing machine, only few months old. Fills
technician coming to see machine tomorrow. See what he says
SOURCE: elba ew 7100 washing mc. heater and spin cycle not working
It appears your heater element or CCU/timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: elba ew 6001 spin cycle
Hello, If
your Roper washing machine does not agitate, spin or drain, you have a
problem that needs fixing. The average do-it-your self offer can do this job without hiring the professional technician. Each problem indicates a
separate repair, but while you have the washer apart, it never hurts to
check things while the back is off and the parts are off the washer. Exercise caution and make sure that the washer is unplugged and the water is off before you begin.
Instructions
And Things You'll Need As Step By Step Instruction.
Washer Won't Drain
SOURCE: elba WA50T54W1 water just overflowing
water level pressure switch tube is clogged with lint or bladder in pressure switch is bad. disconnect power to washer open timer console look for a clear rubber hose disconnect fron switch and blow in tube a couple times reconnect tube and put unit on drain and spin for a second then retrying unit for water level fill put washer on small load water size and test if it continues to fill replace pressure switch...
SOURCE: I need a user manual
Hi and welcome to FixYa, I am Kelly
I am having difficulty with your model number cross reference. Is your washer ELB xxxxx. These Elba series washers are sold exclusively to Sears and you can get the manual from Sears.
Here a direct link to the US top loading model manual:
http://www.elbaappliances.com/admin/pdfs/pdf_usecares/4157_Sears_Washer_UG.pdf
Here is a direct link to the AU / NZ Front loading model:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/4417_AUS_NZ_SGP_Frontloader_Washer_UG2_LRES.pdf
Here is a direct link to the AU / NZ top loading model:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/790718A_AUS_6kg_7kg_8kg_Washer_UC.pdf
Thanks for choosing FixYa,
Kelly
