Question about Kenmore Oasis HE 27082 Top Load Washer
I get a F error message when the cycle is one minute into the start....
What does the "F" error code mean on a Kenmore Top Loader Canyon Capacity Washer?
I DON'T KNOW BUT IT SEEMS I HAVE HAD NOTHING BUT PROBLEMS WITH THIS WASHING MACHINE. MINE IS NOW STUCK CLOSED WITH ALL MY SONS JEANS IN THERE, AND NOW I HAVE THE F CODE TOO!.
Posted on Oct 06, 2007
I have a kenmore oasis elite top loader which is made by whirlpool. we have replaced the machine control panel and the electronic panel behind the dial. the washer is skipping time during the cycle then...
Hi
Thanks for using FixYa. Error oL means overloaded and it flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. To clear this error you’ll have to open the door lid to clear display, remove excess laundry, then restart the cycle. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
My washing machine won't start
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 29, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
I have kenmore front loader that keeps getting an error code of F35. What does that mean
Hi
The error code F35 is commonly associated with the Sud error, which comes on within a minute of running any cycle. It means the Analog Pressure Sensor (small plastic electronic circuit) has gone bad. It costs about $99 to order from Sears although they are on backlog, or you can get it cheaper somewhere else. It could also mean the Air Pressure Tube from the Sensor has a hole or isn't connected.
Once you get the new Sensor, remove the 3 screws holding the top panel inplace - they are on the backside on the very top. Remove the top and look at the far back upper right corner (looking from the front). There is a small crimson & black piece attached to the metal side wall with 5 blue wires & 1 black wire (pressure tube) attached to it. Make sure there are no leaks or disconnects...if not, then replace with new sensor - takes a little playing with to remove the old one & the wires. Replace lid ,it will work like new.
Thanks for contacting fixya.com
Nov 13, 2009 | Kenmore Washing Machines
LOUD RATTLING NOISES ON SPIN CYCLE (SOUNDS LIKE MONEY OR MARBLES IN MACHINE)
you'll need to investigate further. It may even mean bringing in a professional to be sure the vibration damper rods are ok - to prevent future and costlier problems.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | Kenmore 67082 Electric Dryer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
74 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
