EOS Ice Watch In Logo
A
Anonymous Posted on Jul 05, 2013
Ice battery replace - EOS Ice Watch In
1helpful
VX82 X530 Battery for Pulsar watch
The VX82 X530 battery is a replacement battery for the Pulsar watch. It is a lithium-ion battery with a capacity of 3.7V and 530mAh. It is important to note that you should only use a battery that is specifically designed for your Pulsar watch, as using the wrong type of battery can damage the watch or be potentially dangerous. Always use caution when changing a watch battery.
Yyou can try searching for "VX82 X530 replacement battery" or "Pulsar watch battery replacement" on online retailers such as Amazon, eBay, or Alibaba. You may also check with the manufacturer of your Pulsar watch or a local watch repair shop for replacement options.
Mini ice mechine not making ice
Somethings clogged or corroded take it apart to find out what the problem is or purchase a new one. Heres a link to find professional help also http://www.repaircliniccom/RepairHelp/Ice-Machine-Repair-Help Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns and
I need to get the back off my new ice watch to replace battery but I can't? Anyone know how please?
Waterproof or water resistant watches usually need a wrench to unscrew the back. I use a pair of 90 degree circlip pliers. A jeweller would remove the strap and fit the watch into a holder before using the wrench.
Few jewellers would guarantee the water resistance of a watch after fitting a new battery. If it is required a watch be returned to its original specification it must be returned to the manufacturer or an agent for battery fitting and pressure testing.
Some watches have a back that is pressed into place. Fairly easy to prise off but very difficult to replace without the tools. This type does not have the grooves a wrench fits into.
Ice watch that i cannot open
you can open your ice watch most likely with a sharpen knife, but be carefull.
AED ARS AUD BRL CAD CNY DKK EUR MXN NZD NOK COP GBP RUB CHF USD JPYMy...
Need a nut for Scrat articulated toy
TECHNICALLY YOU WOULD HAVE TO BUY ANOTHER SCRAT AND NUT IF YOU CAN NOT FIND THE NUT GO TO A TOY SHOPPE BECAUSE THE MANAGER COULD PROBABLY FIX YOUR PROBLEM.
2answers
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Top EOS Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an EOS Watch Expert? Answer questions, earn points and help others
