Question about Encore ENUWI-G2 802.11G WIRELESS USB 2.0 ADAPTER (54 MBPS)
My USB device is no longer recognized
Hi! Everything was functioning fine for several months,then all of a sudden, my conecction was lost, my system do not recognize the USB device.I change USB sloths,check the cables, applied another USB pen drives instead of my non-functioning wireless USB device,I plugged another USB device in case this one was damaged; I desinstalled and reinstalled the device and software;I even went back to a earlier restoration point.It is driving me crazy,the computer tells telling me that it does not recognized the devuce.Hope somene be abkle to hel p me. Thank you for your eventual advice
  • 59 Answers
Seen this happen many times...it stems from a corruption of the plug and play drivers enumeration key in the registry...the fix is quite elusive...the key is cheap...pick a different brand to replace it with save yourself the grief of fighting this battle. Hope that helps.
Posted on Aug 27, 2007
4 Suggested Answers
  • 39 Answers
SOURCE: My device is no loner recognized
Go into the device manager, click on View > Show hidden devices. Look under unknown devices or under USB for unknown devices. Also check under the section relating to the type of usb device. If you find an Unknown Device, or a device with an exclamation point, right click on it and uninstall. Disconnect the device, reboot and install the drivers/software for it if any. If it's still not working check it in another computer. If you cannot get it to work in either machine, the usb plug of the device is probably damaged. Possibly a loose solder joint. Have the manufacturer send you a new one if its still under warranty.
Posted on Aug 26, 2007
  • 59 Answers
SOURCE: Mi USB device is no longe recognized
Well the fact that it says it can't load the device but sees it, is a pretty good sign actually...first off check the drivers for the device... good luck
Posted on Aug 28, 2007
SOURCE: My USB wireless device is no longer recognized
Hi, I have seen this type of thing B4, & it sounds to me as if your USB WiFi has gone faulty? Really the ONLY way to check is to try another USB WiFi unit.
Posted on Sep 04, 2007
I have sahara al-096 notebook and keep getting a usb device not recognized message how can i fix it. i have tried so many suggestions from the web to no avail. pliz help. im running windows vista
I have the same problem, my Sahara Notebook Image book's usb ports are all not recognizing any usb device i have tried to reistall the os but nothing happening, so what can i do coz the recovery disk was lost.
Nov 03, 2009 | Dell Dimension 8300 PC Desktop
My MX1100 cordless mouse no longer recognized
It sounds like the Drivers for the Mouse aren't be installed. Since it is a wireless mouse and receiver it will need separate drivers to function properly. If it came with a CD I would try re-installing any software that came on the disc. If not (I'm assuming its a Logitech Mouse here) I would visit the Logitech website (www.logitech.com) and see if you can locate Drivers there.
Jul 08, 2009 | Computers & Internet
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Canon MP240
Have a look at this link
http://windowsfixup.com/2009/03/usb-device-not-recognized-fixes/
"Delete the INFCACHE" has worked for me in the past.
Also I found that I was using a non USB 2.0 cable which caused the "unrecognized USB" problem. Once I used a proper USB 2.0 cable it was fine.
Hope that helps.
May 11, 2009 | Office Equipment & Supplies
USB Flash drive suddenly not recognized in WinXP
Ive included here a link that helped me fix a problem with my flash drive that was giving the same problems. perhaps you could take a look at it.
http://www.hat.net/geeky/node/221
Oct 27, 2008 | Computers & Internet
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Light turns on but My Computer does not recognize the drive
The problem is just with EXTERNAL.
Hdd is fine...Just change the external or buy new
Nov 18, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Aug 25, 2007 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Encore ENUWI-G2 802.11G WIRELESS USB 2.0 ADAPTER (54 MBPS) Logo
164 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
