Question about Canon i9900 InkJet Photo Printer
"Banding" on Prints
Like DirtDoctor who stated: "I am having a problem with banding on prints from i9900 even after much cleaning and alignment attempts. It seems to get worse further into printing. I have tried various maintenance to no avail. Is this a printer head issue?" -- I am experienceing the same problem, PLUS: Black ink smudges happening on prints. Had great prints up until recently, when the bands started appearing.
  • 1 more comment
  • kinMT May 10, 2008
    I have the same problem on a i9100 model and I have tried the same solutions. I am trying the manual head cleaning now, hoping that plain rubbing alcohol is the appropriate solution. I was wondering if using 6 mo. old off brand ink would cause it?
  • RDEXPRSS Jun 25, 2008
    Cleaned the heads and it worked for one page and then it's back doing it again. I cleaned again and ran a Print Head Check and the Cyan is still banding...  I've deep cleaned twice and it still doesn't work.
  • daddywx May 11, 2010
    I'm thinking I'm having the same problem. The printer has worked wonderfully for several years. I printed out a 13X19 scenic shot and noticed a lighter band in the blue sky on the last part of the print. When I looked closer the blue on the whole sky is not solid. It looks like there are very light streaks of white left with every pass that the print head makes. Any idea's or feed back would be appreciated. I noticed one answer that said to clean the print head. What is the "proper cleaning solution?"
    Sergeant:
  • 390 Answers
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Posted on Aug 30, 2007
SOURCE:
HEAD CLEANING DOES NOT FIX GAPS IN NOZZLE CHECK
Head cleaning is for fixing horizontal band. If some point of head cloged, print out will show horizoantal banding. For vertical banding, try using head alignment. Have yo tried printing without high speed (disable high speed option)
May 20, 2010 | Epson Stylus C84 InkJet Printer
Why am I still getting banding even though test prints are ok.
Sounds like you've picked up some dried ink on the print head or ink holder. I would suggest removing all the ink cartridges and the ink holder (see directions from Canon) and clean the bottom with rubbing alcohol and a Q-Tip or cotton cloth. DON'T use paper towel, it leaves lint. Check the rollers also to make sure they don;t have ink residue on them. Be cautious when working inside your printer.
Jan 24, 2010 | Canon i9100 InkJet Photo Printer
Banding
If your print head alignment is good, try printing at the slowest setting for the mean time until the banding is gone.
Jan 14, 2010 | Epson Stylus 1400 InkJet Photo Printer
"banding" on photos
It sounds like you need a new purge assembly, that's the unit on the right where the printhead parks. It does the cleaning and also primes the printhead during printing, the ink can clog in the tubes and pumps and if you are printing photos, I would replace it before wasting any more photo paper.
Dec 14, 2009 | Canon i9900 InkJet Photo Printer
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Magenta horizontal banding on all color printout
I suggest that if your machine is under warranty you call out HP, as I have heard that they don't support these machines with parts therefore you will get a new machine.
Good Luck
Dec 09, 2008 | HP Photosmart 3310 Printer
Horizontal banding on prints
try aligning the print heads before cleaning them
Oct 10, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson 2200 printing nightmare
try printing all 7 color individually as a 1st step in diagnostic so you'll know w/c color is actually giving you the problem, no need to do the software this is a hardware problem, it could be one of the ink cartridges,
cheers
Aug 28, 2008 | Epson Stylus 2200 InkJet Photo Printer
INK BANDING
hi what printer do you have may be i will send you sevice software to get heads ect good clean
Mar 10, 2008 | Epson Printer
Horizontal banding
have you tryed to update your drivers on the printer
Dec 15, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Canon i9900 InkJet Photo Printer Logo
303 people viewed this question
Clive
Clive
old marine
old marine
Ekse
