Question about Canon Pixma MP500 All-In-One InkJet Printer
Printer when i try to make copys it comes out one color a pinkish color.
Does it work ok in print mode (documents off the computer) or is it doing the same thing? may need to clean the printhead, the nozzles can get clogged try doing the head cleaning (I'd avoid deep cleaning unless nothing else works as it uses too much ink) if that doesn't work, you can remove the printhead, take the ink out and clean the inside and bottom of the print head using cotton swabs and rubbing alchol. May take many cleanings to get the blockages cleared. If none of the above works and you know you have ink, you may need a new print head, you can order online thru canon's website. Good luck!
Posted on Sep 16, 2007
  • 55 Answers
Your black, yellow, and blue ink cartridges are empty, go to your local ink cartridge store or Staples, or Bestbuy. The only ink left in the printer is the red.
Posted on Aug 25, 2007
SOURCE:
The printed copy shows the red color as pinkish or magenta.
Assuming that you have the printer set up correctly and are using the latest drivers for the printer and the printer software, this is probably caused by clogged ink nozzles in the black, yellow and cyan inks. It may also be down to compatible rather then geinuine inks being used. Try the print head clean function and see if that helps
Apr 01, 2011 | Computers & Internet
Pinkish tint in photo color copies ....... Is there a way to adjust the color ?
The "secondary" colours are produced by mixing the "primary" colours. One of the "primary" colours inside your inkjet cartridge is out of ink, and the resulting "actual" mix is not the "theoretical" mix.
Refill or replace the ink-cartridge.
Apr 05, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP printer not printing true color all of a sudden.
Altho the cartridge is new, you may have used all of the ink of one color. Pictures take an enormous amount of ink to print and all three primary colors are used to create the hues and colors indicated on the picture. Try a new color cartridge and see if that works.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
Toshiba 1210 Photocopier printing dirty copies
u have to replace the drum cleaning blade wont b easy if ur not a tech try and keep ur hands off the drum and blade when replacing 7734748865
Mar 11, 2009 | Toshiba Office Equipment & Supplies
Ink Color Issues
Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
Sep 11, 2008 | HP Photosmart 3210 Printer
Photo printing
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
This report provides useful information about your print cartridges, including status information. If the self-test report shows a problem, clean the print cartridges.
Feb 10, 2008 | HP Photosmart C3180 All-In-One InkJet...
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Canon Pixma MP500 All-In-One InkJet Printer Logo
91 people viewed this question
Clive
Clive
old marine
old marine
Ekse
