Question about Candy ICW101TR Front Load All-in-One Washer / Dryer
Drum not spinning
My machine will fill with water but will not spin. Even If I empty the water on the dryer programme and try to dry, it won't spin. The belt appears to be ok and the pump appears to be working fine. Any suggestions?
  • 247 Answers
SOURCE: Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Posted on Jan 31, 2007
  • 249 Answers
SOURCE: CBL 160 not spinning
itcould be speed control module, If the motor was gone it would not wash.
Posted on Apr 01, 2008
  • 868 Answers
SOURCE: hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
Posted on May 24, 2008
  • 903 Answers
SOURCE: Candy Model CE10 won't spin
It sound like the carbon brushes in the motor may need changing. It sohuld still be okay to get repaired, as most machines have generic brushes for all of thier models. It's worth calling an engineer and suggesting that the brushes have gone in the motor to get a quote on the repair job. Some engineers will come out and give you a free quote anyway.
Posted on Oct 30, 2008
  • 19396 Answers
SOURCE: Candy CNW156 washer/dryer: spins empty, won't spin under load
If the belt and the motor are OK, then tell your friend to check the motor coupler, the MCU (motor control unit).
See also the following link : It doesn't spin.
Posted on Dec 01, 2008
  • 38 Answers
SOURCE: spin not working on some programmes and on the dryer
first of all its the problem of control board as the circuit is short so some programms are supportive and some are not.but as it does not spins this also has to be checked If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Mar 14, 2009
0 characters
1 Points
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Aug 15, 2015 | AEG Washing Machines
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Washer fills and empties but won't wash or spin
If the motor is spinning very rapidly when it should just be tumbling then it sounds like the tacho has gone or come loose on the motor.It may well need a new motor or there could even be a fault with the main programmer
Apr 17, 2010 | Tricity Bendix AW1000W Front Load Washer
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Apr 11, 2009 | LG Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
