Question about Dell 1600n All-In-One Laser Printer
Machine does not copy
Whenever the Start Copy button in depressed the message on the screen says 'LSU error'. End result is no copy.
  • tshai Aug 29, 2007
    I changed the printhead but the LSU error persists
    Could the problem be the mechanism that controls the movement of the scanner unit?
LSU Error occurs when your printer printhead is damaged. Change your printer printhead, the printer will be ok.
Posted on Aug 26, 2007
When machine shows ready to copy n just after i press start button LSU error appears on the screen
It is can be very simple: You may have runaway staples inside; try to shake it
Apr 03, 2014 | Office Equipment & Supplies
Error message
copy on my machine then i tray to copy
May 06, 2013 | Brother MFC-7340 All-In-One Laser Printer
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
LSU ERROR MESSAGE ON little screen when photocopying
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Mar 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
LSU error code
Do you have the old cartridge? Because the message you are getting makes no sense if you can copy and not print.
The chip on the cartridge may be corrupting the machine software.
I will explaine why I say this. LSU fault, is a failure of the laser unit within the printer/copier. If it had failed, you should not be able to copy or print, The machine should not function. The laser unit is what makes the image on the drum. So neither print or copy should work if that was a true LSU code.
Did you purchase a cartridge made by another company other than Xerox? If so try returning it.
As I say, an LSU code should make the machine totally unpoerable, not partially functional.
I would try the old cartridge if you have it to see what happens.
Let me know if you have tried swapping cartridges and I will look into this more for you.
Sep 16, 2008 | Office Equipment & Supplies
Printer Problem
What model printer is this? The C2424 does not have a laser.
Are you 100 percent sure it is a model C2424?
There is no LSU status code for that machine.
May 14, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Unable to print message on the LCD
press MENU then the blue copy button (b/w) then fourtimes the arrow up button quite quickly after another.
Machine should switch to maintenance mode and all lights will flash.
Mar 11, 2008 | Brother MFC-5840CN All-In-One InkJet...
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
Dell 1600n All-In-One Laser Printer Logo
290 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
