Question about GE Profile Spectra JGBP90 Gas Kitchen Range
F7 my oven keeps tring to clean it self? the oven keeps flashing F7 and beeping. i can not get it to stop, i even let it go through the 4 hour self cleaning process. it clean it self and 30 minutes after it finished, the oven again begin to flash F7 and beeping. the oven want stop, i had to unplug it. please help. thanks
  • 1 more comment
  • Anonymous Nov 24, 2007
    Was using left rear burner on high. Suddenly control panel was automatically trying to turn on Broiler by itself. Would hit clear, it would go back to clock then ~5 seconds later would rotate between trying to turn on Broiler Hi, Broiler Lo and "F7" code.
    Just me but an oven trying to turn itself on would be a bad thing.
  • irratatedx2 Jul 04, 2008
    My gas ge profile keeps showing a F7 and beeping. We unplugged it but it keeps doing it. The clock works but no other buttons work except the off button and five minutes after you press off, the thing beeps and F7 returns.
  • Anonymous Aug 19, 2008
    F7 display, beeping, oven won't work. Stove top works.
    Sergeant:
    Champion:
  • 310 Answers
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
I just fixed my F7 GE Oven. The ribbon cable on the control module was misplaced. disconnect the ribbon cable, cleaning it and re connecting fixed the problem for good.
Posted on Dec 28, 2007
  • 725 Answers
No F7 in my tech sheet Could it be a F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad if you want to do it yourself let me know...
Posted on Aug 26, 2007
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Oven door is locked and won't open
Sorry to hear the "self clean" Gremlins are at it again. Several things have happened, none good. During the cycle at full power for several hours, a circuit on the control board has failed. Various errors are now keeping functions from occurring normally, although sometimes door switches fail causing similar anomalies. At any rate 'self clean' eventually becomes 'self-destruct'. Boards run 150-300$ . Hope info helps- Thanks-ED
Feb 27, 2010 | Kitchen Ranges
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
Pushed the clean button, the oven locked, and the screen started beeping and flashing f9 or f7. I hit cancel, and the oven is still locked and the clean button is sill flashing.... It has been 10 hrs!
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^%$
Jun 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ge oven JTP15 beeping and flashine F7 error
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE JTP15 Electric Single Oven
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Does not go into self clean only beeps
here is a link for your owners manual click here
To set Self-Clean:
1. Close the oven door.
2. Press the appropriate Clean pad.
• CLEAN flashes.
• SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
• “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning
settings.
“HVy” (Heavy Soil, 4 hours)
“MEd” (Medium soil, 3 hours)
“LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs
the self-cleaning time.
5. After four seconds, the oven will start cleaning.
• If the door is not closed, beeps will sound and ‘door’ will
display. If the door is not closed within 30 seconds, the
self-cleaning operation will be canceled and the display
will return to the time of day.
• CLEAN will appear in the display.
• LOCK will flash in the display. Once the door locks,
LOCK will remain steady.
• The cleaning time will start counting down in the
display.
Please take the time to rate this solution
Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
761 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
