Question about Apple iPod nano
İpod nano not seen at explorer and itunes
Hello, When i plug in my 1st generation i-pod nano to my computer via usb; neither my xp nor my itunes sees the ipod... What can i do? (i already tried resetting nano) Thank you,
Move the hold button to hold and bak then press menu and the middle button together 4 about 10 seconds and the apple icon will appear this os how reset ur ipod so ur computer can detec it and try downloadin i tunes again
Posted on Aug 29, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
- check the cable - check the connections on the bottom of the ipod for bent pins, or dirt - make sure ipod battery is fully charged - if you have all your library backed up, reset ipod to factory. You will lost all settings etc. though. - check usb ports are working properly with no conflicts or driver issues (control panel\system\hardware\device manager) - uninstall usb ports on pc, let pc redetect them
Posted on Aug 26, 2007
SOURCE:
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
I have ipod nano 1st gen and my ipod wont detect by itunes even my explorer using USB 2.0, i have firewire port wall charger when i try to plug it it charge but idont know if it will work to computer cause...
There might be a few issues here:
1. Your ipod software needs to be updated
2. Your usb cord is bad
3. Your usb port is not working properly
Either find someone that has a firewire port and update it via itunes, or use someone elses computer to update your ipod's software.
www.huskyipodrepair.com
http://repair-scratched-ipods.blogspot.com
Jan 26, 2010 | Apple iPod nano
I pod nano not reconized by laptop with vista usb device not reconized code 10 appears
Which USB ports are you using? I just had this issue on a customer's computer and it turns out that a 5 port USB 2.0 hub they had installed in the pc wasn't functioning properly and so I would get a code 10 on their iPod nano. I plugged it into the onboard USB 1.0 ports and it installed correctly and synched. I would suggest trying other USB ports. If that doesn't work then go to Programs and Features in Control Panel and uninstall all apple products and then reboot and reinstall iTunes.
Oct 15, 2009 | Apple iPod nano 4th Generation
Ipod usb help
im not for shure what OS you are running but with XP and newer it should read it. try downloading itunes
Nov 13, 2008 | Apple iPod nano 3rd Generation
Downloading music from computer
Musicmatch songs won't work on Ipods. Musicmatch has been discontinued since it was acquired by Yahoo last year. If you have songs in MP3 format those can be used in ITunes.
Jul 20, 2008 | Apple iPod nano 8 GB Pink (3rd Generation)...
I pod wont connect to itunes
Try another computer just for the kicks of it and see if does the same. Your computer has this little program deep down call iTunes helper that's suppose to link the USB iPod to iTunes. If it's not working right nothing will happen when connected. If the iPod works on another machine, iTunes helper is the problem or also even bad USB port could be the problem. Send me an update and I'll keep helping you troubleshoot. - Scotty
Apr 29, 2008 | Apple iPod nano 3rd Generation
Miissing e drive
Try updating or reinstalling iTunes.
Jan 02, 2008 | Computers & Internet
Connecting 3rd generation nano
well, 1st u should uninstall itunes and re-install itunes for free by going to itunes.com. then make sure all the settings are right so it will reconize it. if dat doesnt work, email me ur problems to [email protected]
Nov 06, 2007 | Apple iPod nano 3rd Generation
Apple iPod nano Logo
98 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
