Question about Pentax Optio 50 Digital Camera
Computer connecting to camera
Hi I have a Pentax Optio 50, which i have had for almost 2 years. I have never had any problems plugging this into my Mac G4 at home via the USB cable. Recently I had to replace my Hard Drive and get new OS software. I had been running Panther, but i decided to upgrade and get Tiger 10.4.10. When I plug my camera into the USB port either on the keyboard or directly into the computer, my mouse and the whole computer locks up and won't do anything until it is unplugged. The camera manual says the driver will be loaded automatically or will be located on the net. However this does not seem to bew happening. Is this a camera issue or is a Mac OS software issue? If anyone can advise I would appreciate it Thanks Dean K.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Posted on Aug 24, 2012
SOURCE:
SOURCE: pentax optio s5i
Hold the OK key for 5 seconds while powering on the camera. this unlocks the menu and key modes.
Posted on Dec 04, 2007
science gugu
  • 10 Answers
SOURCE: need driver software download for
try this website
www.pentax.com/models/
Posted on Oct 04, 2008
  • 15 Answers
SOURCE: Windows vista not compatible with pentax optio 33l
If you're using an sd card or most other standard memory cards you can buy a card reader very cheaply and plug it into the usb of your computer, your computer may even have a reader built in
Posted on Sep 03, 2009
lock123
  • 6831 Answers
SOURCE: How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 22, 2010
  • 102366 Answers
SOURCE: I have lost my cdrom
Don't connect your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Mar 19, 2011
Lost my cd
Hi, It seems the CD jsut has a ACD see software.
You can download it online.
lemme get you the link...
Oct 01, 2008 | Pentax Optio M20 Digital Camera
I have lost my cdrom drive for my pentax optio 50 digital camera. I have bought a new computer, how do i download my photos
Mar 19, 2011 | Pentax Optio 50L Digital Camera
My Pentax Optio M50 is suppose to be plug and play but when I plug it in to my desktop it tell m "usb device not recognized" What should I do now??
There are to modes on all digital cameras. The camera mode where you take pictures with it and the admin mode where you see these pictures and configure the settings etc. Please put the camera in Admin mode and then connect to the computer. It will be recognized.
Mar 10, 2011 | Pentax Optio 50 Digital Camera
Hi - I am trying to connect to my computer to print pictures of my Pentax Optio E10, but I am not getting a recognition from the computer when I plug my camera in.
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 25, 2010 | Pentax Optio E10 Digital Camera
Is there a driver for Pentax Optio Diver Windows7
http://www.pentaximaging.com/support/manuals-and-literature/
You might want to consider NOT connecting your camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Jul 09, 2010 | Pentax Optio S5z Digital Camera
Optio M20 Digital Camera: I have a pentax optio m20 digital camera and I wan...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 17, 2010 | Pentax Optio M20 Digital Camera
Pentax optio S digital camera
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Nov 01, 2009 | Pentax Optio E10 Digital Camera
Need new driver for vista/pentax optio 50 digital camera
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Jan 03, 2009 | Pentax Optio 60 Digital Camera
Pentax Optio 50 Digital Camara
Are you just plugging the camera straight into the computer? Does it come with software to install? Try plugging the camera in while the computer is off and then turn the computer on with the camera plugged in. Otherwise get a SD memory card reader that the SD card can plug directly  into and this connects straight to the computer.
Sep 03, 2008 | Pentax Optio 50 Digital Camera
Pentax Optio 50 Digital Camera Logo
50 people viewed this question
Top Pentax Cameras Experts
Ekse
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
