Question about Sony Ericsson W200i Cellular Phone
Charging My phone wont caharge via the normal charger, i swapped it at carphone warhouse for another but it still wont charge the phone. However i can charge it via the usb connection. Any ideas?
  • Anonymous Mar 07, 2008
    my inbox text messages are dissapearing
    my inbox messages keep dissapearing
In my mobile vidio songs run but stop affter some time
Posted on Feb 11, 2009
I want some anti virus
Posted on Nov 26, 2008
    Problem Solver:
  • 6 Answers
Your chargers may be broken or wires come lose in it or you could try moving the connection that goes into the phone around when its in there
Posted on Jan 01, 2008
SOURCE:
Phone wont charge
Good Morning My Dear;First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 30, 2012 | HTC Hero Smartphone
My Toshiba Portege M200 just stopped charging and wont even turn on? Is this the battery? Or what? The charger will be plugged in the wall and plugged in the laptop but nothing?
Try removing the battery and see if it will boot without it
Then check the caharger, charging light should be green and steady on the charger itself
If it is flickering, it meand power is not making a circuit, test charger jack with a DC volt multimeter with one probe to the outer side (earth) and one on the inner (positive). If this is ok, check the charging socket is not loose (if it is, will need replacing).
After that, suspect the power strip or charging / powerboard is dead on the motherboard
Mar 22, 2011 | Toshiba Portege M200 Tablet PC
My jet s8000 not charging
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Hope this help in solving the problem....
Nov 16, 2010 | Samsung Jet S8000 Cell Phone
Phone not charging via wall adaptor nor USB
Does the phone charge with all other chargers? USB cord, car charger, etc? IF so I'd say it's the wall charger. You can take it back to the apple store and they will swap it out for you. If you don't have an apple store near you, tech support can set up a mail in repair/replacement.
Dec 04, 2009 | Apple iPhone Smartphone
I took the battery out, and now it wont get past the LG logo,
its a system failure, cz i had it, take it in to either tmobile or carphone warhouse shop and they will give u a new 1
Jun 06, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Charging phone it went off wont come back on
Remove the battery and clean the contact points. Also plug in the charger and try to switch your phone on. Also notice if the normal charging logo/picture is appearing or not. If the phone does not come ON while plugged in with the charger, then its a problem of the phone. However after cleaning the battery, put it back and try to switch ON without/with the charger and let us know the results............sodeep
May 03, 2009 | LG enV VX9900 Cellular Phone
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
Unable to charge
Same problem here but phone is 14 mo old. Just stopped charging even though it says it is. Got new battery, same thing. Charged battery in different phone and was fine. swapped and it works. so... phone is bad somehow.
Apr 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
LG KG800 charging problem.
if you already change the battery;' theres no problem with the battery; i think the problem is software try to reset the factory setting if dosen't work/ reinstall software
Feb 04, 2008 | Cell Phones
Sony Ericsson W200i Cellular Phone Logo
107 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
