Question about Motorola Mobility RAZR V3m Cellular Phone
Motorola RAZR V3 drowned in river water
Hi, My Motorola RAZR cell phone had fallen accidentally in to a local river which has good amount of turbidity. Later I let it dry and blown air with air drier. When I tried to charge the battery , I am seeing the key board flashing for a while and then it stops. Nothing can be done. I replaced battery from a friends similar phone and still it didn't worked. How can I get this cell phone which looks good get repaired? Your help will be deeply appreciated. thanks, Anil
  • rsucesso Dec 19, 2007
    I got myself into a swimming pool with it in my pocket. It's dead now.
Pray
Posted on Sep 21, 2008
You didn't say how long you allowed your phone to dry after it took the swim, nor how long it was in the water. Both are important in trying to guess how much damage may have been done. If the time in the water was very short (very) then there may be hope. If you allowed the phone to dry for a long time (possibly a day or even two) then there is hope as well.
You are right to state that the water had a high turbidity. It's not actually the water that will kill it, it's the stuff in the water.
One thing to think about would be to actually take the phone apart as far down as you can (and dare depending on your skill and knowledge of getting it back together). Once you've taken it apart, rinse it a couple of times with isopropyl alcohol. Doing this may once again suspend all the "stuff" that was left when the water evaporated. and the alcohol shouldn't leave any residue. After you've rinse the phone, allow it to dry for a day or two. Yeah a day or two may sound like a long time to be without you're phone, but it doesn't work right now anyway, so err on the side of caution. Now you may be tempted to use a hair dryer, I don't recommend the hair dryer. You could actually get some components of your phone too hot and cause yourself problems. If you want to I've had good results from laying electronic components on top of a heat and air vent in the house. The heat coming out (at this time of year) should not be warm enough to cause any damage and even the cool air (in the summer) gets good air flow to the device and helps evaporate any moisture, unless of course you have really high humidity.
Anyway, I rambled some there but I hope I've helped at least a little.
Posted on Feb 15, 2008
6ya staff
SOURCE:
How to enter subsidy password for motorola razor v3
You can get the Free subsidy code entering instructions or unlock code entering unlocking instructions from here
www.mobileunlockguide.com
and Unlock it step by step...
Motorola RAZR V3 Unlocking Instructions
Warning: Do not enter any wrong unlock unlock codes on your Motorola RAZR V3 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola RAZR V3 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola RAZR V3 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
Sep 25, 2011 | Motorola Mobility RAZR V3
Unlock razr v3
Which Country Network Lock now?
You can get the Unlock code and Unlock Instructions at
moz-screenshot-7.pnghttp://www.theunlockspot.com/motorola-razr-v3/rs10wp9/
follow the Instructions and Unlock it step by step:
Motorola RAZR V3 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola RAZR V3 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola RAZR V3 mobile phone, your phone may get hard locked and sometimes become unusable.
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola RAZR V3 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Mar 17, 2011 | Motorola Mobility RAZR V3
I have 2 razr v3 phones can I clone the second phone for use on a river trip?
it is not possable to clone a digital signal..it your v3 is a gsm you can clone the sim chip..but if all else fails,add the other phone to your plane..
Mar 11, 2010 | Motorola Mobility RAZR V3
Accidentally locked motorola v3 0000 nor 1234 opened it up.
The service provider will in most cases unlock the phone for you. contact them first.
If they wont unlock it for you, get it unlocked at a website like this http://globalunlock.com/phones/home
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
How to re install browser of Motorola razr v3?
You can create that yourself if you know the required parameters of your service provider.
May 25, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3 - keypad non responsive
sir it may be because accidentally the phone would have made contact with water... my advice is give the set to local service station and change the keypads... hope i have helped you.. thank you sir...
May 03, 2008 | Motorola Mobility RAZR V3
Vibrate on Motorola V3 RAZR
Hi, your vib motor probably has dirt or stray hair so its not spinning, or it has just seized.
Simply bring to a local repair shop for a cleaning - about $15, if thats no good have them replace the vibe motor, cost is about $25-40 including install.
If you can't find a shop to do it let me know, we do those all the time
Jan 31, 2008 | Motorola Mobility RAZR V3
Motorola Network Pin Blocked
Hi
I have a RAZR V3 that my son was playing around ,I don't know what he did but when he gave the phone back to me it was off and when I turn it on to make a call the phone says -Enter Unlock Code- I have no idea what's the unlock code ,when I entered 4 zeros like-0000- and hit OK , the phone says INCORRECT CODE-TRY AGAIN. I tried a bunch of numbers with no luck. I can only enter 4 numbers at a time . NOW I THINK I'M LOCK OUT and cannot use my RAZR V3 anymore. PLS. I NEED HELP TO UNLOCK THIS PHONE .
Nov 20, 2007 | Motorola Mobility RAZR V3
Opening V3
(mouth to mouth it sounds as if its drowned) try drying out very slowly with hairdrier it does depend on how long it was in the water
Aug 31, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
