Question about Kodak EasyShare DX4530 Digital Camera
Lens Mechanism Issue
Camera is 4 years old and has taken very detailed pictures. Recently the zoom operation has become 'stiff' and the auto focus is not at sharp as it was. Can the lens assembly be accessed and cleaned or lubricated? Kodak's cost of repair is excessive and I have 3 accessory lenses that are not usable with Kodak's current offerings.
  • 274 Answers
Yes, the lens can be cleaned and repaired. But you need to almost completely disassemble the camera. If you are very good at mechanical repair on small items you can fix it. You need to be very patient. If you have big fingers like I do forget it. It's why I hired women to do my fine assembly work. You need the "jeweler's" touch if you know what I mean. The inside workings of the camera are really small and require a Magnifier with a light to see. Jewelers screw drivers and tweezers. Use Methanol to clean and not acetone. Alcohol works but Methanol is better. All the connectors are micros and irreplaceable if broken. The screw sizes (0-80 series and smaller)are mixed so care must be taken when replacing in the right location. If all this doesn't scare you then good luck.
Posted on Sep 16, 2007
  • Jerry Hess Sep 24, 2007
    What did you finally do?
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
Mar 24, 2012 | Canon Digital Rebel EOS 450D EOS Rebel XSi...
Previously i had a problem with the lens as it did not came out but I managed to arrange it.. Now when I switch on the camera it turns off immediatley without allowing me to take any picture or viedo.. The...
Please recheck on the work that was done earlier as the mechanism could be jammed and not reponding to shut down. SInce the lens was taken out and reset if the auto focus/zoom mechanism was struck or jammed this can cause the camera to shut down.
Jun 29, 2011 | Samsung S760 Digital Camera
Focus error? The camera won't focus. Focus Error is displayed in the viewing screen. Zoom action & everything else seems to work fine. Won't focus, won't take pictures.
This is a known issue with Fuji S3000 cameras caused by dust and dirt that get in through the loosely mounted lens mechanism, there are only three solutions.
  1. If under warranty you can send the camera in for repair.
  2. Saturate around the lens with WD40 and wiggle the lens until it becomes responsive again every month or so.
  3. Dismantle the camera and clean out around the internal gear-box and lens components about once a year.
May 03, 2010 | Fuji FinePix S3000 Digital Camera
When i turn the camera on, it cycles through opening the lens and zooming in and out but won't focus and then says "turn camera off and back on" but the same thing happens.
Sounds like there is some issue with the lens mechanism. Most probably something like a grain of sand fell into the cogs in the zoom mechanism (been taking pictures on a beach? ;). Dirt gets into the mechanism through the gaps between the zoom barrels and the camera body. One tiny grain of sand is enough to cause the lens mechanism to jam or malfunction.
Unfortunately, this is a problem with pretty much all compact zoom cameras. Usually there is not much you can do with this. First thing I try in cases like these is gently tapping the camera to shift whatever might be blocking the mechanism. If unsuccessul, then only way I know to fix this is completely stripping the lens to clean it or swapping the lens with one taken from another camera ("donors" available on ebay ;).
If you are not keen on tinkering with your camera I would suggest selling it on ebay - TZ3s with lens mechanism issues still fetch pretty good prices.
Sorry if this is not much of a help, but unfortunately there is no easy fix to this one.
Good luck,
Nov 08, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Quantaray 70-300
Sounds like the aperture inside the lens is broken. You shuld send it in for service.
Aug 07, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Auto Focus not working for Canon EFS 18-55mm lens
I see this same problem occuring all over the internet on Canon lenses. Autofocus not working any longer. For some stupid reason the lense will lock up and quit autofocus while other lenses will work fine. A light pull on the lense focus ring away from the camera body will give a noticable pop or click which unlocks the jammed lense. Try it if you are having troubles with your autofocus. This is a very common problem and worth giving it a try.
May 30, 2009 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Auto focus quit working.....Help !!
google its user manual
changing lens from stock might be the issue
or 8 years auto focus sensor may be stuffed
Apr 11, 2017 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
Viewfinder jammed
The mechanical link between Lens on V/F element has broken - Only Olympus will be able to do anything for you -check out the support site.
Aug 19, 2007 | Olympus Camedia C-5050 Zoom Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
51 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
