Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Burner not igniting
I have one top burner that does not spark when I turn the switch. It does spark when the other swithces are turned. How do I replace the burner switch on the front of the oven?
  • Anonymous Dec 23, 2008
    well I figured out it was a specific switch to the buner that doesnt ignite by itslef. but how do you open the tom and what is the 'manifold panel'?
  • 725 Answers
The switch is just behind the nob WB24K10003 SWITCH-BURNER VALVE you will have to open the top and remove the manifold panel to get to them. let me know if this helps
Posted on Aug 25, 2007
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas burner won't light unless gas is turned down to the low position.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
Feb 20, 2014 | Jenn-Air Cooktops
I havef a KitchenAid Gas Range Model KGSS907... and one of the ignitors on one of the burners is not sparking. I tried to take the stove top off to check the wire to the ignitor but don't see how to...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to it..so turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
GENE
Aug 27, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
I have a Kitchenaid superba gas range slide in, model #KGST307HBS9. The nob of one burner, only, the left rear, will initiate the electronic spark that will light burners. When that nob is turned to...
Pull out the bottom drawer and you will find the spark module. I strongly suspect it is weak. Here is a video that shows operation:
This one shows the module on the backside but I looke dup yours and it is below in the backside of the bottom drawer. Ok here is what i think The igniters could be dirty and I have a video showing how to check that plus another video to show how to remove those pesky switches on the top burners and spark module operation.
TOP BURNER SPARK IGNITION
SEALED BURNER SCREWUP
Jan 02, 2010 | Kitchen Ranges
Igniters won't turn on & unwanted flammes
You say you have no sparks coming from your gas range, but your rear burner is lighting. That doesn't quite make sense. If some of your burners are lighting, then the problem can't be with the spark module. The spark module sends a spark to ALL the igniters at the same time. That is, EACH burner switch, when turned to ignite, will cause a spark to go to ALL the burner igniters at the same time. Just watch the next time you turn one of your burner switches on, and you'll see a spark at all the burners simultaneously. This is normal. I suspect that you have a bad igniter switch or wiring harness. For example, if you have a front burner that won't light, but WILL light when you turn on another burner, the spark is being provided by a working burner switch. This is also normal. Now, am I assuming that your back burner will not light properly, but will light if you use the front burner? If so, the burner switch for the rear burner is probably bad, or the wiring harness has a break somewhere. Now...if you have no sparks, as you say, but randomly a burner will light, then I would suspect a bad spark module. I hope I'm not confusing you here. In a nutshell: One burner doesn't work, but all others do - bad burner switch, or wiring harness. No burners light, or light randomly - spark module. I hope this helps you.
Jul 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
124 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
