Question about EliteGroup K7AMA Motherboard
Motherboard k7ama-ellite group
Im using os win xp, ram pc 400 512,amd duron,1.1gh processor.the problem is it will not shutdown .the os is newly stalled running good..thanks
  • 883 Answers
Try disabling the power saving features at the startup BIOS screen.
Posted on Aug 26, 2007
  • Marty marty Sep 03, 2007
    if rated as "almost there", what issue remains?
6ya staff
SOURCE:
Memory settings for ddr
http://www.motherboards.org/mobot/motherboards_d/ECS/K7AMA/
Since the Processor Front Side Bus (FSB) support is 200 or 266MegaHertz (MHz), the ram memory will be DDR Sdram at either 100Megahertz or 266MHz.
That is PC1600 and PC2100, respectively.
2GB's maximum TOTAL amount for motherboard.
1GB per ram memory slot - Maximum
If you have a Socket A (Socket 462) AMD processor with a 200MHz FSB, I suggest DDR Sdram at 100MHz. (PC1600)
AMD processor with 266MHz Front Side Bus = either PC1600, or PC2100. I would go with PC2100.
Voltage in BIOS Setup is 2.5 Volts. That is is the JEDEC standard voltage, for DDR Sdram.
Ram timings will be dependent upon what the ram memory supports.
IF you have just ONE ram memory module ('Stick'), it goes in Slot 1.
(DIMM 1)
This is the ram memory slot the Processor reads first.
http://www.cpu-upgrade.com/mb-ECS/K7AMA%28V1.5%29.html
http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/ecs_k7s6a_vcore.html
http://8000.hillbillyhardware.com:8000/Reviews/ecs_945gcd-m/ecs_945gcd-m.html
"When it comes to innovative motherboards ECS is not a company that first comes to mind. Not since the days of the K7AMA that offered DDR266 and PC133 memory options for AMD's K7 line of processors has ECS released a motherboard that has filled a gapping hole in the PC hardware market space. Lets just hope that the failure rate of the 945GCD-M is nothing like the failure prone K7AMA."
Hmmmmm,
Not doing it for you? Then post more details in a Comment.
Regards,
joecoolvette
Jan 03, 2013 | EliteGroup K7AMA Motherboard
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
Tech spec
This board came out in October 2003. From the Chaintech tech specs:
  • Socket A for AMD Athlon XP / Duron processors
  • AMD Athlon Processors up to 1.4GHz
  • AMD Athlon XP Processors 1500+ to 3200+
  • AMD Duron Processors up to 1.3GHz
  • Hope this helps & please rate this solution fixya. Thanks.
  • Feb 05, 2009 | Chaintech 7NJS-ZENITH Ultra Motherboard
    I want to add more ram in my pc km400/km266
    Oddly enough this board has the following specs: The board supports both Althon and Duron processors up to Athlon XP 2800+ (3000+ with a BIOS update). It can handle 3 GB of DDR333 RAM (or 2 GB of DDR400, but not all types are supported).
    That's the older 184pin DDR ram in PC2700 or PC3200 guises. I can see no reason why it would only accept 2gb of the faster Ram.
    Why not go over to www.crucial.com  and run the online scan to get the true story on your board?
    Jan 05, 2009 | AMD Via KT400 Athlon(XP)/Duron SktA DDR...
    Maldonado223
    best processor
    AMD Athlon, Athlon XP, Duron, and Sempron processors
    200 / 266 / 333MHz front side bus
    for further information visit the link
    http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
    Jun 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
    How to upgrade
    Here is the list of compatible processors for your motherboard:
    AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
    AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
    AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
    AMD Athlon MP 2800+ (Barton)
    AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
    AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
    AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
    AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
    AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
    AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
    AMD Sempron 3000+ (Barton)
    AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
    AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
    AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
    You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
    Apr 03, 2008 | AMD Duron , 750 MHz Processor
    PROCESSOR
    Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
    Athlon (Socket A) (600 MHz - 1400 MHz)
    Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
    Athlon MP (1000 MHz - 2133 MHz)
    Duron (550 MHz - 1800 MHz)
    Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
    Mobile Athlon 4 (850 MHz - 1400 MHz)
    Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
    Mobile Duron (650 MHz - 1200 MHz)
    I Recommend to go for Athlon XP with good cooling fan. :)
    Dec 18, 2007 | EliteGroup K7AMA Motherboard
    K7VT2 with a AMD Duron 1.30 GHz CPU.
    Depends on which AMD processor you would use. If Duron you could go to 1.8Ghz. If you use Athlon XP you could go to 3200+. Athlon MP 2.1Ghz and regular Athlon 1.4Ghz.
    Nov 13, 2007 | Asrock K7VT2 Motherboard
    K7ama AMD duron
    Hi, You can try a couple of possible remedies: 1. If you're using Win98/SE, download shutdown fix from the Microsoft website; or 2. If Win XP, update your networking card drivers; and/or 3. Reinstall/repair Windows. Hope this be of some help/idea, post back how things are or should you need add info. Good luck and kind regards.
    Aug 25, 2007 | EliteGroup K7AMA Motherboard
    EliteGroup K7AMA Motherboard Logo
    78 people viewed this question
    Top EliteGroup Computers & Internet Experts
    Alun Cox
    Thomas F. Schneider
    Ekse
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
