Question about LG DU-42PX12XC 42 in. Plasma HDTV
Problems I have several red ines on my screen that are 1inch thick going up and down on screen. I have called lg and tv is over 2 years old so they wont warrenty it.
    Problem Solver:
  • 6 Answers
Its a hardware problem. If its an expensive TV it may be worth getting someone to look at it and get it fixed. If its a cheaper one better off buying a new one.
Posted on Aug 26, 2007
I have an LG 50PS8000 plasma tv which is nearly 2 years old. For the last few months its has occassionally been getting a red haze over the entire screen which either dissapeared on its own or went if you...
I've also had a popping noise on our 50" LG plasma TV, however the picture has not gone, but has turned grainy and colors are weird. Can this also be a blown fuse or a more severe problem (ysus board or similar)?
Apr 08, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a LG plasma 42PC1D (4 years old). For the
I had the same problem a few months after buying the TV, called LG and they sent a tech to replace two boards in the tv. No further problems since.
Dec 21, 2009 | LG 42PC3D 42 in. Plasma Television
LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Sep 22, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Tv convergencen is off convergance is off the red green blue colors ineed to ente on service ineed a code and more information
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
May 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
42 LG Plasma
It can be fixed but about $300 in parts.
May 18, 2008 | LG 50PX4DR 50 in. Plasma TV
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Feb 11, 2008 | LG 50PX4DR 50 in. Plasma TV
Red line
as you said, this is a scan problem, but maybe not from the 'board' itself but maybe the flex cable. sometimes it becomes loose and it makes a bad connection between the panel and the board. if the tv is under waranty: please call LG service customer they are very friendly and thay can give you a reference number that will get you a free repair in an authorized LG service center... anyway thats the way we work around here (qu?bec,canada). let me know
Aug 05, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Hyundai 42inch plasma tv
If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
Mar 20, 2006 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
LG DU-42PX12XC 42 in. Plasma HDTV Logo
51 people viewed this question
