Question about SanDisk Sansa m230 MP3 Player
M240 sansa mp3
I have a sansa mp3 m240 and i connexted it to the computer and the screen is now saying finalizinf update what do i do to fix it?
    Scholar:
  • 155 Answers
Try removing the battery of the player for around an hour then put the battery back in. If it still freezes on that part maybe your songs are corrupted try reformatting the player.
Posted on Aug 26, 2007
SOURCE:
Not enough space? sansa m240
try formatting the device..that must solve the problem...if it doesnt,use sansa updater to update its firmware
Sep 07, 2009 | SanDisk Sansa m240 MP3 Player
Help Me! Sansa m240 say only 'Finalizing Update
need more info but if it is to do with windows update just be patient and wait for it to finish, if it takes way to long reset your computer using the reset button and windows will recover its self and tell you what went wrong and what option you have, ok, not a problem at all.
Jun 22, 2009 | SanDisk Sansa m240 MP3 Player
Only displays initial power on screen (SANSA m240 1.0GB)
keep the hold switch to right side and connect to pc...then format the player or try updating the firmware..tht must do...
Jun 17, 2009 | SanDisk Sansa m240 MP3 Player
Scandisk sansa m240 mp3 player
You can manually transfer files thru My Computer>Device Name (m240). Just drop the files, no folders, into the device. Best of Luck.
Oct 04, 2007 | SanDisk Sansa m240 MP3 Player
Sansa m240: 0 MB after wrong firmware update
If your Sansa does not recognize MSC (Mass Storage Class) mode, then your PC will not be able to communicate properly to it. Sandisk can fix it but you will have to email [email protected], to ask them how to proceed from here. Give them the following information: 1) Sansa device model 2) Firmware version on your device 3) What computer OS you have 4) Problem you're experiencing (what you've done) ZT3000 Beta tester of "0"s and "1's"
Aug 14, 2007 | SanDisk Sansa m240 MP3 Player
Mp3
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240''s there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that''s frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately. <>
May 04, 2007 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
My Mp3 player does not plug and play properly in my Xp computer
Youmust have instaled MEDIA PLAYER 10 , oderwise your computer will NOT see the device
Mar 07, 2007 | SanDisk Sansa m240 MP3 Player
New SanDisk Sansa m240 MP3 Player
Hey regan have u fixed it yet?? Mine is doing the same thing and it wont turn on at all well write back!! ~sam~
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
R u holding the holding the Menu button down for about 3 seconds?
SanDisk Sansa m230 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
