Question about Sharp AL-1641CS Laser Digital Copier
Error message - won't function.
Alternating L and 1 are appearing. Copier will not function and makes a grinding noise when turned on. Checked the head lock. It is unlocked. Unit is NOT new, has considerable wear.
  • JavierV Nov 17, 2007
    I have the same problem, but after a while L and 3 appears, a tech told me that is the home position sensor, i'm waiting for test it.
  • 328 Answers
Usually it is the gears in the fuser asm. One of them is cracked or imbedded with toner and grease. Open the right cover and remove the two screws holding the fuser in place. First remove the back cover and unplug the fuser cables.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 26, 2007
  • Jay Blair
    Jay Blair Aug 26, 2007
    If it is the main fuser gear broken, you can order a new one from sharp or me for about 12 dollars. A new fuser will cost about 129.00
SOURCE:
E2 alternating with 10 - error message. If I turn it off, it makes a loud rattling sound noise when turned on
if the paperjam was removed incorrectly, it could have tampered with the timing of the gears or maybe even broke a gear
Jul 03, 2016 | Office Equipment & Supplies
C163 on b52izhub c5
3B02,3B03,3B04 - IH malfunction.Try reset the error code:
Turn OFF the copier,press and keep pressing the Function key and turn ON the copier.Keep pressed the Function key until appaire the Trouble reset message on the display.Release the Function key ,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Dec 23, 2013 | Konica Minolta Bizhub C452 Copier
C350 grinding noise does not power up
Open the right door and remove the fusing unit and turn ON the copier.If the copier turn ON and the error code displayed the problem in the fuser drive transmission mechanism(gears),if not working remove the rear cover and verify the main suplly unit and the main motor.
Mar 20, 2013 | Konica Minolta bizhub Office Equipment &...
The copier displays an alternating L and 1. The
the display flashes L1 when turned on and will not make copies
Feb 12, 2010 | Sharp AL-1642CS Copier
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
C0070 still appears
the toner housing sounds like its been turned by hand when the toner has been replaced, it is possible that the drive gears in the unit have been stripped(worst) or could be that the rotation locking mechanism has been dislodged and just needs repositioning
Jun 26, 2009 | Konica Minolta Office Equipment & Supplies
Sharp copier makes grinding noise
Contact your dealer for service. You may need to have mechanical parts replaced.
May 05, 2009 | Sharp AL-1642CS Copier
Delet code
It's an calibration error caused in the optics section. Make sure there is nothing on the scanner glass but the cover itself. Turn the power off, wait 30 seconds and turn the power back on again.
Do you hear any grinding noises when the machine is initializing?
Aug 08, 2008 | Sharp AR-5316 Advanced Digital Imager...
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
Sharp AL-1641CS Laser Digital Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
