Shuts down on its own
Laptop computers combine the power of a personal computer with the
flexibility of a mobile device.
They are excellent tools for businesspeople and students, providing access
to relevant materials on the go.
When laptops shut down without being prompted, this typically indicates that
the unit is overheating, has a malfunctioning battery or requires a software or
BIOS update.
While isolating the problem can be time-consuming, correcting the problem is
simple.
Check for BIOS updates on the laptop manufacturer's website.
Check for operating-system updates.
Make sure that there aren't any obstructions to the air vents.
These will cause overheating and make the laptop shut down.
Remove the laptop battery, open all hatches and blow out any areas you have
access to with compressed air.
This should dislodge any obstructions.
Retrain the battery, which may have lost its ability to hold a complete
charge.
Unplug the laptop and use the battery until it runs out.
Once dead, plug the laptop in, turn it off and recharge the battery in full.
This may take at least 8 to 12 hours.
Repeat this process at least three times.
Check to make sure that your fan is working.
http://www.daileyint.com/hmdpc/overheat.htm
Check to see if there are any keys stuck/depressed.
If so, use a paperclip and fit it underneath the key and gently pry the end
that is stuck.
Make sure the laptop is off before attempting this.
Observe where the boot process ends and starts over.
In most cases, this will give an indication where the problem occurs.
If the laptop reboots early on in the process, for example when it is
detecting the hard drive, chances are good it is a hardware issue.
If the reboot occurs further along in the process, like when it is loading
operating system files, there may be an issue with operating system software.
Test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a
secure dust free connections and are not faulty
Make sure all leads that are attached to your drives dvd\cd have secure
connections and are not faulty.
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working
device and to have an end for a computer to be able work properly.
Motherboard and a hard drive any leads between them will fail before your
motherboard or your hard drive check all power and data leads make sure they
are securely seated even the cd/dvd drives need to have current go through make
sure these devices are working
Check your computer ram modules for secure dust free seating you might even
remove the ram modules to check for dirt on modules and in the module socket
and cmos battery make sure it has charge and they are dust free and securely
seated some motherboards cmos batteries are soldered in
If your computer runs long enough scroll to bottom toolbar (bottom of
screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might
uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be running your computer over its
limits causing memory dumps
also under processes see what is ticking over in the background you might
have a virus again if you see something you
dont need to be and users you will see who is using your computer
You might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory
Advisor tool for a list of guaranteed compatible modules. first you
will need to select the manufacturer from a drop down list then select your
product line
from a drop down list then select the model then click find it will take you
directly to compatible ram also you will have an option to scan your system
You should always ask for a guarantee on the compatibility of the ram before
making any purchase
Might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Capacitors look like small metallic canisters and they are found in many
different computer components including computer monitors, computer
motherboards, video cards, power supplies and a variety of other consumer
products.
A bad capacitor can cause a variety of computer problems,
but if you can identify the faulty capacitor you may be able to replace it and
save your computer.
Capacitor
Capacitors, sometimes also called
condensers, are used to store energy in an electric field.
In the context of computing, capacitors
are used to block the direct current being circulated around the motherboard.
A typical capacitor should last up
to 15 years, but some computer manufacturers use substandard capacitors
resulting in shorter lifetimes.
Computer Problems
When a capacitor has gone bad on a
computer you may experience a large range of problems. The computer may have
trouble booting up, or it may shut down without notice after running for only a
short period of time.
The most common problems associated
with faulty capacitors are that they cause unexpected computer crashes and
general reliability issues ranging from read/write issues to distorted screen
images.
Identifying a Bad Capacitor
To identify a bad capacitor you
will need to open your computer case and locate the capacitors on your
motherboard.
A bad capacitor may exhibit
swelling at the top or the base of the capacitor or it may sit at an awkward
angle with the motherboard, so compare the various capacitors in your computer
in terms of size and placement.
Additionally, a bad capacitor may
have a funny smell or it may have a brownish residue leaking from the top or
the base.
Prevention
Manufacturers claim that capacitors
may go bad because a computer is not receiving enough power from a power
supply, because of an overclocked processor or because a computer is operating
in an environment with too much heat or humidity.
However, some capacitors
prematurely fail due to faulty work on the part of the manufacturer.
If you have a bad capacitor be sure
to do research as to the lifespan of other products made by your manufacturer.
Identifying bad capacitors
http://www.youtube.com/watch?v=ngA4k32jLGc
Capacitor replacement
http://www.youtube.com/watch?v=s0Pn2tEjY04
How to check a capacitor
http://www.youtube.com/watch?v=U4tnHA0phcc
Replacing a leaking capacitor
Could be a problem with the Hard
Drive or the Hard drives PCB
http://www.onepcbsolution.com/
SOURCE: compputer shuts down abruptly
It sounds that you might having problem with your power supply unit, try replacing it with another working one. Problems like this one can be caused by defective power supply unit.
SOURCE: HP PAVILION LAPTOP SHUTS OFF AND REBOOTS AFTER A FEW MINUTES
This issue could be caused by any of the below possibilities
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
SOURCE: vertical lines, screen freezes, laptop shuts down
it most likely doesnt run on windows me so that theory is out.Take it to dell or call someone to fix it
-CG
SOURCE: PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
