Problem for Cuisinart Coffee and Espresso Makers
Generic problem for all Cuisinart Coffee and Esp...
How to clean the coffee maker & set war...
Cuisinart DBGB300BK
What is the best way to clean the coffee maker &/or set the self-clean? I cannot get it to turn on, but maybe it is because we do not use the clock on the device......
Where do you set the 0-4 hour time to keep warm? A guest played around with it and it only stays warm for about 30 min now.
Please help.
Thx,
pbkutner@comcast.net
Solution #1
posted on Mar 28, 2009
Rank: Guru
Expert
Rating: 86%, 4818 votes
In order:
1 and 2) Clean the coffeemaker by puring in 1/3 caraffe vinegar, and 2/3 caraffe water. Either use the self-clean light or brew it as if it were regular coffee - just press the on button and then press the self-clean button, and it will begin.
3)
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing. For example, if you set
the ASO for 40 minutes and 25 minutes have
already elapsed, the Grind & Brew™ will shut
off automatically after 15 minutes (40 minutes
minus the 25 elapsed equals 15 minutes).
-Tha Mp3 Doctor
Popular Solutions for Coffee and Espresso Makers
Cuisinart Grind and Brew 10 Cup Coffee Maker - Black and...
1 Solution
Cuisinart Coffee on Demand 12-Cup Coffeemaker
1 Solution
Questions and Unsolved Problems for Coffee and Espresso Makers
I'm coffee lover and want to buy a coffee espresso maker in the price range between $600.00 and...
(More)
I'm coffee lover and want to buy a coffee espresso maker in the price range between $600.00 and 850.00.I live in Panama Central America. Can you suggest a maker and model???
Tkanks,
Boris Allara
b.allara@gmail.com
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
display problem on tv . after tv tuned on all screen appears in blue color i e picture is not...
(More)
DISPLAY PROBLEM ON TV . AFTER TV TUNED ON ALL SCREEN APPEARS IN BLUE COLOR I E PICTURE IS NOT DISPLAYED
we are having problems finding a seal for our Tracanzan Alfa stove top espresso maker. I am unsure...
(More)
we are having problems finding a seal for our Tracanzan Alfa stove top espresso maker. I am unsure what size it is but it is around 6-10 cup i think and is approx 4 yrs old We live in Darwin, Northern Territory, Australia and are inquiring as to where we can find a replacement. Thank you, Sarajane
My DeLonghi Cafe Duo was working perfectly for over a year. Then one day it stopped. No power at...
(More)
My DeLonghi Cafe Duo was working perfectly for over a year. Then one day it stopped. No power at all. Can it be repaired?
