Question about Brother SX-4000 Typewriter
Brother ax-12 cable detached
A classic brother ax-12 was in great condition until a cable appears to have become detached inside; it seemed to be looped around 2 pulley type components and involved with moving the print "head" back and forth; i will be forever impressed with the powerr of the web if someone can give me technical tips on how to reattach this cable; also is nyone familiar with where i might download a brother ax-12 service manual (preferably free of course), thanks
  • hellochief Aug 28, 2007
    thanks for the suggestion! in looking at the pulley it does not appear to be damaged; it just seems like the cable ends popped out of the right side pulley (white plastic with grooves around the center for cable to spool); i guess if i could remove the white pulley, i might be able to superglue the cable back in; unfortunately i'm not even sure of how the cable should be oriented on the spool; i know this is an old unit, but is anyone aware of a service manual or related documentation freely available on the web that might be helpful? thanks again
  • 328 Answers
The pulley is broken and you have to remove it and try to drill a hole to attach the cord. A new pulley should be available from Brother. I have seen repairmen jam a small piece of metal inside the cracked area, but it is a little bit tough if you have no experience. You have to remove the covers and the main logic board and the carrier motor asm. Then the pin holdong the pulley. A shop would charge about 50 dollars.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 26, 2007
  • Jay Blair
    Jay Blair Aug 28, 2007
    Try justmanuals.com
SOURCE:
I am looking where can I get a manual for ax-28 typewriter
The site below claims to have your manual in pdf download format, but you have to become a member of the site or possibly pay a fee to do so before downloading
http://www.devicemanuals.com/support/brother-ax-28-pdf-manual-82928.html
Nov 18, 2015 | Office Equipment & Supplies
Hood release not working
Do you mean its detached from the cable? If so, see if you can reach the attachment point for the cable and pull in direction of the cable to release. If this is helpful a thumbs up or clicking helpful would be greatly appreciated. Good LUCK.hood-release-not-working-mi3qs3kfzvqijsqzkmg2vt51-3-0.jpg
Jun 07, 2014 | 2000 Ford Windstar
My daughter just got a used Brother AX-12 typewriter but it doesn't have a manual. Where can I find a manual?
yoYI would so to ask.com and type in manaul for brother ax-12 typerwriter.
Or, you could just google Brother Ax-12 typewriter and then click on the information and the manual will probably be listed.
Mar 30, 2011 | Brother GX-6750 Typewriter
I need the owners manual for my Brother Electronic Typewriter AX-12
Hi
On the Brother site, there is one available for the AX-20.
Maybe it is simlar to your machine?
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_AX20_EN_1594.PDF
Hope this helps!
Nov 02, 2009 | Brother SX-4000 Typewriter
Am looking for a used script wheel for a ax 10 brother typewrither
Wholesale Distribution: http://www.rhinomart.com/brother-405-printwheel-1-script-10-12-lot-bro405/
This site has them for $29: http://www.officetronics.com/bro405-script-1012-printwheel-p-1478.html
These guys want $26.71 for a new one: http://www.business-supply.com/script-10-12-pitch-cassette-daisywheel-for-brother-typewriters-word-processors_BRT405_product.html?src=bizrate
I checked eBay, but there is nothing....
Please rate me for this solution.
Aug 28, 2009 | Brother Office Equipment & Supplies
Ultra Classic has miss when cold and a vibration
Hi Lcampeau12, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 16, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Is there such a thing as a co-ax cable to input converters?
Before you go that far, realize that the cable itself may be the problem. Usually poor picture quality can be traced to poor cable connections. Also, another possibility is poor connections inside the tuner of the set. I assume that you are using a cable box. Some of the newer boxes have direct video connections which will connect as you describe. Check the condition of all of the cables and connectors before yo invest in anything.
Keep us posted.
Dan
Feb 17, 2009 | HP Expresscard TV Tuner For Windows Vista...
GE Profile Side by Side Refrigerator
This is probably the ice maker water feed becoming detached from the back of the appliance. This is a fault of a leaky watervalve or low pressure allowing water to drip into the feed pipe where it freezes building up until the pipe blocks where water pressure causes it to bacome detached. Change the water valve and refit the pipe ensure there are no airleaks into the freezer.
Jul 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
Brother SX-4000 Typewriter Logo
109 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
