I just replaced impeller and reinstalled lower unit.I thought I was careful not to move shift rod,but I cant get rod conected.After trying for hours to reconect it seems like the boat shift handle wont go into reverse.Would the problem be with the shift rod adjustment or the boat shift handle.
SOURCE: Shifter jumps out of forward gear on 64 9 1/2 hp Johnson motor
sound like the shift fork, or fwd gear is damaged in the lower unit.....special tools are required for this repair .....if you got them cool, if not seek a shop for further assistance.......hope this helped...GL
SOURCE: how to remove shift rod linkage to pull lower unit
goto local library get book on unit!!! :)
SOURCE: I need to install a water pump impeller I just
Usually you just buy outboard motor gear oil and that does it. (about 70 to 90) I think. Usualy comes in a squeezy tube for injecting it under pressure.
It needs to be injected from the bottom drain hole and you force it in till it starts to come out of the top drain hole.
Most outboards work like that so I assume yours probably will.
SOURCE: how to change waterpump on
You have to undo the gear change linkage.On the side of the leg is a small plate that comes off.Put the engine in N and undo the bolts.It's a metal rod that runs from the motor to the g/box.Hope this helps
