Bit more information would be handy? whats wrong with the plug? is there just no power going to the iron? have you tried replacing the fuse? have you tried taking the wires out and making sure there is a strong connection between the wires and the screws? if your iron isnt turning on it may not even be a problem with the plug. it could be an issue with the motherboard in the iron
SOURCE: need way to open the iron 3302
Usually start at the cord end to locate internal screws to get top off then down to the next layer
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
SOURCE: I have a Rowenta 1700
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
SOURCE: shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
SOURCE: Rowenta iron won't heat
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
