Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Cannot get access to Water pump to clear it.
I think the water pump is blocked but don't know how to get access to it to clean it out. The user manual shows a picture of a removable cover where the filters are but my model does not appear to have this, The manual also has an asterix which says some models only on the water pump section. I have also checked the outlet pipe and there appears to be no blockages so concluded that it is the pump blocked. How can i clear it?
  • 4 more comments
  • wattsy Aug 25, 2007
    Thanks Krazytech, I cannot see how to access the water pump there appears to be no internal access to it from within the machine as it has an all plastic bottom with no screws. Assume access is from outside but cannot see where, can you advise?
    Thanks Kraytech, the model number is SGS43C12GB/15 manufactured in feb 85.
  • iloverubbish Nov 17, 2007
    Hi there, sounds like I have a similar problem! My dishwasher will not drain water but it isn't blocked because I can blow down the outlet pipe. Do you know how I can take off the plastic bottom so I can get at the all the different bits? Or can I do anything from inside - but there doesn't seem to be any access. Thanks for any help, Kevin
  • wattsy Feb 08, 2008
    SGS43C12GB/15 was the model of mine. I got access to the pump by putting it on its side and taking the bottom panel off, but be carefull when lifting the bottom away as there is a piece of polystyryn foam that rests on the bottom of the panel and I think supports the float mechanism. It is not held in by any fittings and is held in place by the weight of the float mechanism. Mine fell away as I took the bottom off, it was not a problem to put back in but I had to make sure it was the right way up...so when you take the bottom panel off do it slowly so you can see which way is the right way up for this foam bit. Once you have the bottom off you can see the pump easily, it was held in by some easy clips and easy to remove and clean the pump out, mine had a piece of elastic band which was stopping the propellers turning. Once cleaned it works perfectly again. Hope this helps
  • Anonymous Feb 13, 2008
    I have a bosch classixx dishwasher and it is less than 5 years old, it was working well untill 48 hours ago and now has water at the bottom which will not drain away. Is there any way of evacuating the water without taking the machine apart.
    Presumeably the pump needs cleaning..
  • hairy_lairy May 11, 2010
    I too have water at the bottom and the filters don't seem to be blocked. But how do you access the pump? The model is Bosch SGS43C12GB.
I wouldn't recomend taking a dishwasher apart unless you know exactly what you are doing.
Taking the spray pump housing off to clean it out can be very tricky.
If you do manage to do it you will need a new jubilee clip for the heater box.
Diver 1
Posted on Feb 08, 2008
  • 725 Answers
The sump is in the bottom center front. a retangle screen with a center filter should unscrew counterclockwise the drain pump is hard to access but if you want to let me know and I can walk you thru it..let me know if this helps
Posted on Aug 25, 2007
  • Franklin Ouchida
    Franklin Ouchida Aug 25, 2007
    you can't access the pump from inside the dishwasher.. but you should see a drain. it Whould be in the bottom center..what is the actual model number there are 20 different models of the SGS43C12?
2 Suggested Answers
SOURCE:
BIKER T
  • 909 Answers
SOURCE: Water will not drain away at end of wash programee
METHODS TO REMOVE COVERS ON EACH MODELS ARE DIFFERENT. BASICALLY, REMOVE THE LID FIRST THEN CHOOSE WHICH COVER(S) YOU WISH TO REMOVE. FOLLOW THE PERRIMETER OF THE COVER AND REMOVE ALL THE SCREWS SECURING IT. ONCE SCREWS ARE REMOVED, SLIDE COVER OFF AND INSPECT FAULTY COMPONENT.IF YOU CANT SEEM TO GAIN ACCESS TO THE DESIRED AREA, I SUGGEST A TECH. BECAUSE THE BASE WOULD HAVE TO BE SEPERATED FROM THE BODY CAUSING CAUSING FLOAT SWITCHES ETC TO FALL OUT. NOT FUN IF NEW TO IT.
Posted on Aug 23, 2007
Dishwasher won't empty water and stops with 1, 3 & 4 lights flashing.
It could be your drain hoses are blocked . damaged or kinked . Also the strainers may need a clean and when you take the stainless plate out you have easy access to pumps to give them a clean as well
good luck
Aug 11, 2014 | Fisher and Paykel Dishwashers
Simpson silencio 980 won't start cycle
HI I think you should take the waste pipe and blow down it you'll need a bit of puff, there's also the possibility that the waste pump is blocked with debris you will need to take it apart to clear it failing that a new water pump may be necessary or if your lucky you can access the pump by tilting the machine after removing the mains lead and the water pipe inlet there should be an isolation tap attached to the water pipe good luck in your task cheers eric
Nov 16, 2017 | Dishwashers
Hi, My Bosch Logixx 8 is showing error F18 which I think means the filter is blocked. we have lost the manual so how do you get the filter out. Do we need to drain the machine first? Is there an online...
F18 is either the pump discharge is clogged or the machine is oversudsing. If it is oversudsing, make sure that you are using an HE detergent and use less detergent. (Make sure to note the minimum detergent line
To clean out the pump discharge, have a bucket ready for when you release the hose. First, set the cycle selector to Off and unplug the washer. Open the service door and remove it. Next loosen the screws and remove the protective foil. Remove the emptying hose from the holder and take off the cap. Drain the water from the hose. Replace the cap. Then carefully remove the pump cap and drain the rest of the water from the pump. Clean out any foreign objects from the area (housing, threads of the pump cap, etc). Make sure that the impeller can turn. Then replace the pump cap and tighten the screws (the handle should be vertical). Replace the emptying hose and the foil protector. Replace the service door and plug back in. Then fill the dispenser II with 1 liter of water and then start the Drain cycle. Let this water flow through to the pump.
The manual is available from Bosch. Go to http://www.bosch-home.com/us/WAS24460UC.html?source=search and click on Additional Documents . Then click on User Manual. This will redirect you to the correct page. Select your specific model and the language and click on the manual with the IU designation. The pictures to go with the clogged pump are on page 9 of the PDF.
The filters that can get blocked are in the water inlets. To clear those, turn off the water to the washer. Select a cycle and press Start/Pause. Wait 40 seconds then set the selector to Off. Unplug the washer. Then remove the inlet hoses. Clean and replace the filters at both sides of the hose. You will need pliers to remove the filters from the washing machine side. Then reconnect the hoses and check for leaks.
I hope this helps.
Jul 09, 2011 | Bosch Logixx WAS2446 Front Load Washer
The washing machine is a wma52 and has a 1 year old new pump on it last year. it will not drain the water away but is not making any strange noises like before. is it the filter?
hello, check the filter if ok then check the drain hose that connects from the pump make sure it's not kinked does it connect to plastic pipe and straight out through the wall make sure this not blocked.if it connect under the sink make sure your sink not is blocked if the pump has failed check the wiring to the pump hope it helps
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WMA52 Front Load Washer
Not cleaning well. appears food and water not draining during cycle. Is there a way to clear drain?
there shouldnt be much food in it to drain?? consult manual for how to access pump for cleaning it is user serviceable.
May 27, 2010 | Bosch Evolution 500 SHE45M06UC Built-in...
Need to clean pump of bosche logix 1600 express. How? Need manual too. It keeps beeping at me ''Pump blocked?'' and I have to drain it into a bucket.
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Pump is item #23 and filter is #24. The main pump is accessible from the rear or under the machine.
Nov 13, 2009 | Bosch Washing Machines
We think we overloaded the machine with bath mats and since then the water did not drain and the machine does not work any more. All buttons are flashing.
your pump is totaly clogged with the math matt sand
you should be able to access the pump from the rear wall,
bring towels you will loose water
remove both hoses from the pump and ensure they are clear, wash the drain hose completly run water through it
make sure you pump is clean and free
to spin
reassemble and and plug back in
errors should clear
Oct 23, 2009 | Washing Machines
Pump outlet is blocked
it was difficult for me to access the pump; so i connected the outlet pipe to my vaccuum cleaner and it did manage to get water out, but the moment i took the vaccuum cleaner out the pump was ineffective on its own. so i repeated this about 10 times and then the pump blockage was cleared and it is able to work on its own again.
Jun 02, 2009 | LG Washing Machines
Aug 22, 2007 | Bosch 24 in. SGS43C12 Classixx...
Not Pumping out water
Possible your outlet filter is blocked. After disconnecting electrical input from wall socket, remove the back panel of washer to see if the pipe from the tub is blocked, clear, also check the outlet filter, clean. If u have the users' manual check how to clean your outlet filter
Nov 14, 2006 | Creda W120VW Front Load Washer
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
490 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
