You have to replace your neutral safety switch / Range sensor after market it will cost u around $100 for the part
SOURCE: 1990 dodge varavan will not go into reverse
It is more then likely either a solenoid or a clutch pack. If you hear a bump and then nothing when you shift, it is probably the clutch pack, if nothing happens, it is more then likely the solenoid. The bad news, it will require a rebuild either way. Reverse gears are some of the hardest to change, and especially on that transmission, it will be quite a process to repair.
SOURCE: 2000 mitsubishi Diamante,one week after a new axle
By the sound of your problem your vehicle has an electronic automatic gear box but correct me if I am wrong..Now this can be caused due to a faulty electronic part but I cannot guarantee this.It may need a diagnostic tool hook up to the car to read the error code.(if it's giving a check engine light )
SOURCE: 2000 mistisubishi transmission won't engage
probably your transmissions plugs has to be cleaned,
SOURCE: I HAVE A 1995 MITSUBISHI
it will most almost certainly be superb last results for you. x737wU60
To come about throughout some concessions, you can look at many
internet pages, as well as the factors by method of which you can
purchase a key
http://www.buytera-gold.com
http://www.buy-d3-gold.com/
http://www.buy-d3-items.com/
