Televison & Video Logo
Anonymous Posted on Jul 04, 2013
Tv not turning on
My tv not turning on i have no remote
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Jul 04, 2013
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080619
Points
34431
Reset the r.control, take out the battery and put again the code and try it.
if the problem persist, clean the contacts battery, and replace by new ones.
clean the keypads. test the remote control with digital cameras or webcan cell see the picture, the LED from r. control must be ON, when you touch any KEY, othewise proceed as indicated above.
I have a oneforall remote urc 3050B00 I have a LG smart TV that I need the code for the remote
Here are the steps to program your OneForAll URC 3050B00 remote to control your LG smart TV:
Turn on your LG smart TV.
Press and hold the "TV" button on your OneForAll remote until the LED light on the remote turns on and stays on.
Enter the 4-digit code for LG TVs. The most common codes for LG TVs are 0030, 0056, 0178, 1265, and 1398, but you can also find a complete list of codes on the OneForAll website or in the manual that came with your remote.
Press the "Power" button on the OneForAll remote. If the TV turns off, the code has been successfully entered. If the TV does not turn off, repeat steps 2-4 with a different code until you find the correct one.
If none of the codes work, you can also try the code search function on your OneForAll remote to automatically find the correct code:
Press and hold the "SET" button on the remote until the LED light blinks twice.
Press the "9" button on the remote. The LED light should blink twice again.
Point the remote at your TV and press the "Power" button repeatedly until the TV turns off.
Press the "OK" button on the OneForAll remote to save the code.
I hope this helps you program your OneForAll remote to control your LG smart TV!
How do I program this RCA nightclub universal remote for my Samsung smart TV
First understand that you need a little patience with this remote, it's a little slow, it may take a few seconds in between pushing buttons for it to react to your TV.
1)
-Turn on TV manually first.
we're going to try and get the remote paired to your particular tv
2)
-Facing RCA universal remote towards TV, press and hold both the POWER and TV buttons on the remote at the same time.. until the RCA universal remote POWER button lights up and is constantly on.
-Then press the PLAY button on RCA universal remote
(POWER button on remote should be blinking after pressing PLAY -- what the remote is doing is trying to program your TV with a list of codes. if your TV does not automatically shut off after a minute, press the PLAY button again. your TV should shut off. wait a few seconds before trying to press PLAY button again if you need to try again.)
3)
Assuming remote turned off TV. Now let's try to get the remote to turn on your TV
On the remote at top right is a REVERSE button, press that. You should see the POWER button on the remote blink once in response to you doing that.
Watch for the power on light on your TV.. your TV may take a few seconds to power on..
Wait a couple seconds. if your TV has not turned back on, press the REVERSE button again. the POWER button should blink once again in response
If your TV did not turn on. You may have to repeat pushing the REVERSE button waiting a couple seconds for the remote to try turning on your TV. For some people this can take several times, if not a dozen times. Just be sure to be patient and wait a couple seconds in between pressing the REVERSE button again. (what the RCA universal remote is doing is going through a list of codes trying to find the right model to pair to)
4)
Assuming the remote finally turned on your TV.. We are almost done. We programmed the remote to turn off the TV and turn on the TV. now we want to press the STOP button on the RCA universal remote to lock in those codes into the remote. After pressing the STOP button the light on the remote POWER button should turn off.
5)
We are done. You should be able to change the channels and raise and lower the volume of your TV.
1helpful
Tryin to conect cox remote to my onn tv but the code isn’t working
MANUAL PROGRAM CODE SEARCH YOUR XR11 REMOTE TO YOUR TV:
1 – Turn ON the TV you will be using with the XR11 remote.
2 – PRESS AND HOLD the SETUP button (bottom left) on your XR11 remote until the LED status light (top of remote) flashes from Green to Red.
3 – Begin manual TV code search by entering 991 on the XR11 remote.
4 – The LED status light will flash Green 2 times.
5 – Repeatedly press the CHANNEL UP button on the XR11 remote to search through the TV codes.
6 – Keep pressing CHANNEL UP button on the XR11 remote until the TV you are programming turns OFF.
7 – After your TV turns OFF press SETUP.
8 – The LED status light on your remote should flash Green 2 times.
9 – Press the TV Power button on the XR11 remote and if the TV turns ON, your XR11 remote is programmed.
Be sure to hold the SETUP button until it flashes Green 2 times after your TV turns OFF.
3helpful
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
I need step by step instructions to program the codes into my One For All universal remote URC-4220 to my JVC tv.
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
8helpful
2answers
The volume control won't work on my sky remote
for a toshiba tv,
press tv
press and hold select and red until the led blinks twice
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
20helpful
4answers
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
