Question about JVC AV-28-BD-5-Bl 28" TV
JVC C-21MU1 / High Voltage Problem
Intermittent power.No high voltage at all. All power control are working,B+ 116V ok Hor.Vcc 9V at TDA8659an ok.All Voltage at the secondary chopper seems working very well,except the output of hor out at pin#39 of TDA8659AN is not oscillating at all.But sometimes the TV will work fine, even for 24hrs continuous used,but if u turn the TV off for about 6hrs,the next time you turn it on again no power again.Keep on pushing the power button on/off the TV will work again. My finding's is something is triggering at x-ray protect pin#52 TDA8659an to cut-off the hor out oscillation at pin#39 of TDA8659AN.Until now I can't get the real culprit. Your assistance is very appreciated.
    Novelist:
    Champion:
  • 236 Answers
Try checking the filter in the 116v line. You may have an intermittent spike coming through the B+ line.(The filter may have decreased in value) Also a small filter in the X-ray circuit could have lost capacitance. There is a low value capacitor (about .047uf @400v) in the collector circuit of the horizontal output transistor that will detune the horizontal circuit causing the HV to go too high. If this cap is intermittent it may be causing your problem. Stargazer Hope this helps
Posted on Sep 02, 2007
SOURCE:
Where is fuel pump harness on a 2000 escalade
DTC P1351 Ignition Coil Control Circuit High Voltage
The enhanced ignition system uses the crankshaft position (CKP) sensor in order to provide a timing input to the control module. Ignition control (IC) spark timing for each cylinder is based on this input. The control module provides the ignition timing signal to the ignition control module (ICM) to control the ignition coil. Each timing pulse detected by the ICM allows it to energize the ignition coil. A large secondary ignition voltage is induced in the secondary coil by the primary coil. This high voltage is switched to the correct spark plug by the distributor.
This diagnostic trouble code (DTC) will set if the VCM- (vehicle control module ) detects an unusually high voltage on the ignition timing signal circuit.
Diagnostic Aids
Intermittent test -- If the connections and the harness check OK, monitor a digital voltmeter connected between VCM terminal C3 pin 9 and C4 pin 18 while moving related connectors and wiring harness. If the failure is induced, the voltage reading will change. This may help to isolate the location of the malfunction.
An intermittent may be caused by any of the following conditions:
A poor connection
Rubbed through wire insulation
A broken wire inside the insulation
Thoroughly check any circuitry that is suspected of causing the intermittent complaint. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
If a repair is necessary, refer to Wiring Repairs or Connector Repairs in Wiring Systems.
Check out this guy's video on GM fuel pump electrical circuit diagnosis !
GM Fuel Pump Relay Testing
Apr 21, 2016 | Cars & Trucks
Microwave pvm1870sm3ss not heating and have no wiring diagram
You don't need a wiring diagram if you have basic knowledge of how a microwave works. The gadget responsible for heating is the magnetron just google to have an overview. How ever it must be powered by high voltage from a transformer. If the microwave indicates it is on yet not powering, just open the cover only don't touch capacitors inside without discharging first to discharge just short the capacitor with an insulated screw driver check for continuity with digital multi meter on the primary of the high voltage transformer if ok change your magnetron and you will have your microwave back and functioning just make sure not to plague on the A.C Mains while you are working on it.
Mar 23, 2016 | GE Microwave Ovens
Meaning of codes? P0118, P0123, P1115, P1121
P0118 = ECT (engine coolant temp) sensor high voltage
P0123 = TP (throttle position) sensor high voltage
P1115 = ECT sensor intermittent high voltage
P1121 = TP sensor intermittent high voltage
Mar 07, 2016 | 1998 Oldsmobile Intrigue
Why does this Sharp CRT TV turn on then click off a few seconds later?
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen - Troubleshooting ... Click Here to BUY TV ...
Oct 31, 2015 | Sharp Televison & Video
Do I need to replace the battery and buy a converter, or buy a completely new one? Is it completely broken?
Normal the high input voltage should influence the output voltage. The120V AC to 9V DC will be blown, but with a bit of luck, your Crosley cruiser will be ok. Only if the power convertor is poorly made, the high voltage could have gone through the convertor and then it damaged everything in the cruiser. Try a new 9V power supply and see what it does.
Jan 19, 2015 | Crosley Audio Players & Recorders
Giving the code E.27
E27 Open Throttle Switch Signal here is a list of all codes E12 No Distributor Reference Signal E13 Oxygen Sensor Not Ready E14 Shorted Coolant Sensor E15 Open Coolant Sensor E16 Generator Voltage Out of Range E19 Shorted Fuel Pump Circuit E20 Open Fuel Pump Circuit E21 Shorted Throttle Position Sensor E22 Open Throttle Position Sensor E23 EST Signal Problem E24 Speed Sensor Circuit Problem E26 Shorted Throttle Switch Circuit E27 Open Throttle Switch Signal E30 ISC RPM Out Of Range E31 Shorted MAP Sensor Signal E32 Open MAP Sensor Signal E34 MAP Sensor Signal Out Of Range E37 Shorted MAT Sensor Signal E38 Open MAT Sensor Signal E39 VCC Engagement Problem E40 Power Steering Pressure Switch Signal E41 Cam Sensor Signal Problem E44 Oxygen Sensor Signal Lean E45 Oxygen Sensor Signal Rich E47 BCM to PCM/ECM Data Problem E48 EGR System Problem E52 PCM/ECM Memory Reset E53 Distributor Signal Interrupt E55 Closed Throttle Angle Out of Range E58 Pass Key Control Problem E60 Cruise - Not In Drive E61 Cruise - Vent Solenoid Problem E62 Cruise - Vacuum Solenoid Problem E63 Cruise - Set Speed vs Vehicle Speed E64 Cruise - Acceleration Too High E65 Cruise - Servo Position Signal Problem E66 Cruise - Engine RPM Too High E67 Cruise - Switch Shorted E68 Cruise - Command Problem E70 Intermittent TPS E71 Intermittent MAP E73 Intermittent Coolant Sensor E74 Intermittent MAT Sensor Signal E75 Intermittent VSS Signal E80 Fuel System Rich E85 Idle Throttle Angle Too High E90 Cruise - VCC Brake Switch Signal Problem E91 Cruise - PRNDL Switch Problem E92 Heated Windshield Request Problem E96 Torque Converter Overstress E97 P/N To D/R Engagement Problem E98 P/N To D/R ISC Engaged Problem E99 Cruise - Servo Apply Problem
Jul 31, 2013 | 1992 Cadillac DeVille
Dual shock 2 wire digrem
The pinout is as follows when looking into the cable like this;
__________________
1 ' * * * ' * * * ' * * * ' 9
\_________________/
Pin Name Description
1 DATA Data
2 CMD Command
3 +7.6V
Dualshock and Dualshock 2 uses this for powering vibro-motors. Voltage on PS2 is 7.6V, however many sites says it's 9V. But it will work on 9V too.
4 GND Ground
5 VCC Vcc
6 ATT ATT select
7 CLK Clock
8 N/C Not connected
9 ACK Acknowledge
~KenjiFox
Jan 07, 2011 | Sony PS2 Dual Shock 2 Controller...
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
Won't Power On
as you have seen inside that no power & no light. problem seems to be in power supply. 1 check fuse. 2 check switching ckt. 3 check for loose contact or print break. 4 now if you get power on & still tv is not ok then check for hor. output transistor in hor. output stage. if you are not tech person please do not try to fix it as high voltage is there inside.
Sep 23, 2007 | LG 30FZ4D TV
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Televison & Video Logo
90 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
