Question about Mitsubishi WS-65869 65" Rear Projection Television
Mitssuisbihi ws 65869
My tv power turns on for a second and then turns off . I received the folowing response from someone . I have an additional question below. Response from TV Mechanic They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer. Thank you for your response above . One additional question - where is t he single convergence IC part#STK393-110 located?
  • jjrichards Aug 28, 2007
    Tried your self diagnosis . The lights blinked just once , then again once . This went on for the 5 times . However we did not that both Fuses F9A04 & F9A05 are open when we put a meter on it . If it only blinked once , short pause another blink it would seem that based on your memo no error detected. However the power light will not stay on . Let me know your thoughts .
    Jeff
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
Posted on Aug 26, 2007
WS-65869 Turns off automatically after about 2 seconds
I have the same exact problem, did you guys got any help?
Jun 23, 2009 | Mitsubishi WS-55313 55" Rear Projection...
My tv will not turn on
Incorrect power supply voltages present...accordianman
Feb 27, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in
It is not hard to find, because they are the largest IC's on the boards. It maybe on the signal bd. if so this is the other board beside the one that has the large flyback with the wires coming out of it going to your tubes. It usually have a large heat sink in back of it silver most of the time with fins.
Aug 25, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitshibishi 65 " HDTV
Check 5A micro fuses F9A04 and F9A05 - If one or both are open,change the single convergence IC part# STK393-110.
Aug 22, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Problem with WS-65869
One of the 3 CRT's being bad is a possibility but more than that at one time no. If the picture doesn't come on at all or any menus showing up the most likely you have a power supply or high voltage issue. Have a technician look at it for the best diagnosis.
Apr 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
199 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
