Question about Whirlpool LSB6200PQ Top Load Washer
Washer stopped in the middle of a cycle
My whirlpool LSB6200pq has stopped in the middle of a cycle. I read another forum and and it pointed to a bad timer. Does it need to be drained first and then restarted? I have replaced the pump before because of a leak so I ruled that out. Could the drain hose be blocked? Thanks for your asssistance
  • 164 Answers
I wouldn't be so quick to replace the timer as those rarely go bad. Start simple and check the lid switch. On whirlpoos they sometimes shift position and dont always close when the lid is closed
Posted on Aug 26, 2007
SOURCE:
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
Spinning cycle not functioning
If the agitator is working during the wash cycle,then the lid switch is bad on the spin cycle.
This video will show how to remove the cabinet to replace the lid switch.
Copy and paste this in your browser.
http://www.youtube.com/watch?v=6XIsK3W_Qcg&feature=player_embedded
May 28, 2010 | Whirlpool LSB6200PQ Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine stopped in middle of wash cycle.
Timer needs replaced try gigling your timer knob and see if you get any reaction dont be afraid gigle it up and down hard sounds like point in timer are burnt
Sep 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer Model LSB6200PQ Top Load
I'm sorry but no, all major appliances now have a one year warranty unless you purchase an extended warranty.
To assist you I need the Make and model number. I also nee to know if you have experienced any water drainage problems in your home. This will help make a determination on what to look for.
May 14, 2008 | Whirlpool LSB6200PQ Top Load Washer
Whirlpool LSB6200PQ Top Load Washer Logo
113 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
