Question about Fuji FinePix E500 Digital Camera
Shuts off when I zoom or take photo
The camera turns on fine, and the screen shows everything that the lens is seeing, but when I try to zoom or take a photo the camera immediately shuts off without retracting the lens.
  • KBART Mar 17, 2008
    I HAD THE SAME PROBLEM WITH MY FUJI FINEPIX E500. I WAS READY TO SCRAP IT, BUT I DECIDED TO TRY MIHD BATTERIES. ALTHOUGH THE BATTERY VOLTAGE OF THE MIHD IS 1.2 VOLTS VS. 1.5 FOR ALKALINE, THE CAMERA WORKED AND HAS CONTINUED TO DO SO. WHY? IT MUST BE THE DIFFERENCE IN THE INTERNAL RESISTANCE OF THE BATTERIES OR THE SOMEWHAT FLAT DISCHARGE CURVE OF THE MIHD BATTERIES. BOUGHT 4 KODAK BRAND MIHD AA WITH CHARGER FROM WALMART FOR $11.00
It might be power shortage... double check your batt...
Posted on Dec 18, 2007
    Problem Solver:
  • 10 Answers
Sounds like zoom has sand in it, Or the camera may have taken a hit to the front of the len's, Lens has to be taken apart, Has to be done buy a camera repair shop/or factory. TC
Posted on Oct 07, 2007
Camera shuts down when 'zoom lens' is used.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
Turns on. Lens zooms in and out, gives me "Zoom Error", shuts off
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Olympus SP-500 UZ Digital Camera
Olympus FE-280
1 year warranty on olympus products, but does not cover physical damage such as impact, water, or sand
Jul 18, 2008 | Olympus FE-280 Digital Camera
Will not focus
First Send me your camera's model (Brand Name)
Some digital and analog camera in these days has features to manualy set the focus in our wish.
Try to disable this feature. And try not to poke or push the lens of the camera. By doing this you may destroy the lens.
And try to reformet the mem stick + try to reset the camera.
(Everything will be resetted, "it will be as if you have a new camera")
Feb 03, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Can't zoom!
dislocation of motor drive gear / need to fix by near camera technician.
Dec 29, 2007 | Olympus FE-280 Digital Camera
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Fuji FinePix E500 Digital Camera Logo
177 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
