Debug session time: Mon Jul 14 09:57:27.345 2014 (UTC - 4:00)
Unable to load image atikmdag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8800f4d0dbb, The address that the exception occurred at
Arg3: fffff88008f85228, Exception Record Address
Arg4: fffff88008f84a80, Context Record Address
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 00000000000006a8
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80003702100
00000000000006a8
FOLLOWUP_IP:
atikmdag+c7dbb
fffff880`0f4d0dbb 488b83a8060000 mov rax,qword ptr [rbx+6A8h]
BUGCHECK_STR: 0x7E
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff8800f4d0dbb
STACK_TEXT:
fffff880`08f85460 00000000`00000000 : fffffa80`0ac95a80 fffffa80`09c35840 00000000`00000003 fffffa80`0d6c9010 : atikmdag+0xc7dbb
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: atikmdag+c7dbb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 53508a3c
STACK_COMMAND: .cxr 0xfffff88008f84a80 ; kb
FAILURE_BUCKET_ID: X64_0x7E_atikmdag+c7dbb
Followup: MachineOwner
2: kd> lmvm atikmdag
start end module name
fffff880`0f409000 fffff880`10319000 atikmdag T (no symbols)
Loaded symbol image file: atikmdag.sys
Image path: atikmdag.sys
Image name: atikmdag.sys
Timestamp: Thu Apr 17 22:13:16 2014 (53508A3C)
CheckSum: 00EAEEE6
ImageSize: 00F10000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Uninstall and reinstall the current driver and if no joy, Try and older version, but nothing over 1yr old. If still not working, try a BETA version if available.
Can't Find Your Driver or Don't Know What Driver to Choose? Please Read This First.
http://support.amd.com/en-us/kb-articles/Pages/find-a-driver.aspx
AMD Graphics Drivers and Software.
http://support.amd.com/en-us/download
***Some generic information on Bug Check 0x7e.***
Bug Check 0x7E: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED.
http://msdn.microsoft.com/en-us/library/windows/hardware/ff559239(v=vs.85).aspx
Resolving stop (blue screen) errors in Windows 7.
http://windows.microsoft.com/en-us/windows7/resolving-stop-blue-screen-errors-in-windows-7
***See if this "HOTFIX" below Applies.***
Stop error message in Windows 7 or Windows Server 2008 R2: "Stop error code 0x0000007E (SYSTEM_THREAD_EXCEPTION_NOT_HANDLED)" or "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)"
http://support.microsoft.com/kb/979538/en-us
Machine ID Information [From Smbios 2.7, DMIVersion 39, Size=3043]
BiosMajorRelease = 4
BiosMinorRelease = 6
BiosVendor = American Megatrends Inc.
BiosVersion = F7
BiosReleaseDate = 01/20/2014
SystemManufacturer = Gigabyte Technology Co., Ltd.
SystemProductName = Z87-HD3
SystemFamily = To be filled by O.E.M.
SystemVersion = To be filled by O.E.M.
SystemSKU = To be filled by O.E.M.
BaseBoardManufacturer = Gigabyte Technology Co., Ltd.
BaseBoardProduct = Z87-HD3
BaseBoardVersion = x.xGigabyte Z87-HD3
http://www.gigabyte.com/products/product-page.aspx?pid=4489#dl
Remove.
fffff880`0476f000 fffff880`047b7000 dtsoftbus01 (deferred)
Image path: dtsoftbus01.sys
Image name: dtsoftbus01.sys
Timestamp: Fri Feb 21 04:49:36 2014 (53072130)
CheckSum: 00047544
ImageSize: 00048000
Driver Description: Daemon Tools driver
Possible BSOD issues in Win7
I would also suggest you remove AVG Completely and replace with Microsoft Security Essentials.
