Question about Dacor ECD230 Epicure Electric Double Oven
Display 11 I think there was a temporary power outage due to a thunderstorm. Upon returning home, the oven display was blank, not lit at all. When I pressed each of the buttons, none of them responded except for the oven light. But when I pressed the "secure-cancel" button, "11" appeared on the display. "11" remains on the display no matter what buttons are pressed. Turning off the circuit breaker results in a blank display screen again. Repeating the process, "11" comes up on the display after pressing the "secure-cancel" button. What is the problem and how can it be fixed?
  • ginetta Aug 31, 2007
    I have not checked to see if the controls or display is shorted yet. My base question is still what does the display "11" actually signify according to Dacor. If the Dacor sofware is programmed to show "11", there must be a Dacor definition on the significance of this display. A supposition of what is "must" be does not answer the basic question.
    Sorry for the misunderstanding. I already knew about the F0-F8 Dacor codes from the owner's manual and the Internet. There were (2) topics in this FixYa page header mentioning "display or error 11" with no answers. That is why a posted another one. Display "11" has apparently appeared on other Dacor ovens and is not a totally a random display. As an engineer by profession, I was asking for a confirmation that display "11" has been accurately identified and what was involved in an actual repair to resolve the issue. Do you have documentation that a fried circuit board has resolved an incident of display "11"? What component part numbers do I need to order to fix the incident? This type of information is what I consider helpful.
Hey, i have a dacor oven that DOES show a falt code and book says it's element relay circut failure, do i have to replace the circut relay board??
Posted on Sep 05, 2007
  • 725 Answers
Your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Posted on Aug 26, 2007
  • 1 more comment
  • Franklin Ouchida
    Franklin Ouchida Aug 29, 2007
    Did you find out if your control and display are shorted?
  • Franklin Ouchida
    Franklin Ouchida Aug 31, 2007
    You may not have a 11.. you may have just the 4 light bars light up. and make it look like a 11 . As I wrote in my first answer. Dacor fault codes are f0-F8. I have see all kinds of weird number and shapes from a shorted controls it has nothing to do with the software program. I know you don't want to hear that the control is faulty . But I was just trying to help you with the question from what I know of working on dacor..and you rate me as NOT helpful..THANKS! and let me know if you find out what a 11 code is I would love to know too.
  • Franklin Ouchida
    Franklin Ouchida Sep 03, 2007
    Wow you want information about a dacor fault code that dacor doesn't publish or not exist. You do sound like a engineer by profession. sorry I will not be able to help you..
SOURCE:
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
WHY IS MY DOUBLE OVEN BEEPING WHEN TURNED ON AND THEN DISPLAYS F1 ERROR CODE?
It means you have lost power. It could be due to a power outage or brownout. Check the user interface, control board, harness, etc. It may also have a short. In that case, consult a professional to check the unit.
Dec 30, 2014 | Kenmore 41389 Electric Double Oven
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
Oven display is blank and oven light does not come on
90% of the time this will be the main control board if neither of the displays work. Here is that board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | Ovens
Frigidaire range ffef3016lbe flashing f-11
You have a shorted out keypad - (F11, 12, & 13) disconnect power, wait 30 seconds and reapply power. If fault returns upon power-up, replace EOC
Aug 21, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Have JKP44GP double electric oven. Few months ago lower oven would not stay on-can set oven to bake, stays on for 1 minute then turns off. Today the upper oven is doing the same. Severe thunderstorm last...
It sounds like you are going to need a control board. You can look for a used one online part number WB27K5210. You can also send your board in to be rebuilt. Corecentrics and Fix your board are two reputable companies.
Feb 22, 2018 | GE Ovens
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Nov 13, 2009 | Ovens
Dacor ECD230 Epicure Electric Double Oven Logo
606 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
