Question about RCA F27TF720 27" TV
Set turns off, resets itself, turns on, repeats .
Off/on usally happens 3 to 5 times in the same pattern. Next time you watch tv it may not happen at all, or will happen 15minutes in or 1 hour in or whatever it wants. It was made sEPT 2002, started this cycling problem after one year of mild home use. No major move was involed.
    Novelist:
    Champion:
  • 236 Answers
I think you might have a bad solder joint in the power supply circuit or a bad solder connection in the horizontal drive circuit. I've found a few RCA's that had a poor connection on a little inductor coil in the base circuit of the horizontal output transistor. A drop of solder cured this problem. Stargazer
Posted on Sep 02, 2007
I have a 50" philips magnavox tv that changes channels on it own and turns itself on frequently. What is causing this issue?
Do you live with someone who likes practical jokes; even silly ones?
There are a number of companies that make remotes that can mess with someones TV or other remote devices.
I have a watch, as a gag, that will self program its remote to operate any TV capable of this feature. With this watch, I can change channels, power status and even reset the TV to factory default state.
Next time this happens, look behind you.
Jan 15, 2013 | Televison & Video
My sony has started turning itself off after 20-30 minutes, each time you turn it back on it will turn itself off after a shorter and shorter run time. Leave it over night and it will start the next day...
It might be over heating. If there is a lot of dust
inside of the back of the T.V. you should take it outside and blow it out with an air compressor.
good luck
Aug 06, 2009 | Sony KV-36XBR400 36" TV
TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
May 23, 2009 | Panasonic Viera TH-42PX80U Plasma TV
My mitsubishi tv model ws55908 will just turn itself off after I have been watching it. It could be as soon as 1 or two hours or 4. it does not happen all the time I can go a month without it happening...
This TV has a self diagnosis feature. When the set fails, push "menu" and "input": buttons at the same time and hold them in for more than 5 seconds. Watch the front panel light. It will blink two numbers five times. Get back to me with the numbers.
Apr 15, 2009 | Mitsubishi WS-65908 TV
Tv shuts off, when I turn tv on it will shut itself off, this hap
When it shuts don, the standby light should be blinking a repeated pattern. PLease update this with the count of blinks. That will indicate the circuit that caused the shutdown.
Thanks,
Dan
Feb 26, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Mitsubishi CS-35313
If it is not a cold solder on the CRT board at the end of the tube (inside)...... then the CRT (tube) is bad. The CRT costs more than the set new.
Mar 24, 2008 | Televison & Video
TV turning off
INtermitant problems as the are called usally mean bad solder connections...the joints between electronic components. this set when it has a problem shuts down. This is safty cuircits. It could be a connector. when the set shuts down. it locks out for a period of time.. DO you have to uplug it to reset it? IS there any sounds. Without know more i would guess its high voltage.
Dec 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Turning on
I have had this happen too. You need to unplug the unit so that it resets itself. After you re-plug it in you need to set the time. If you just reset it without setting the time it will happen again. This has happened to me a few times. Good luck!
Feb 23, 2007 | Cuisinart DGB-600 Coffee Maker
RCA F27TF720 27" TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
