Question about New World 60ECHDGm Electric Kitchen Range
Fuse tripping My cooker keeps tripping the electric and being a woman I can't find where the fuse is on my cooker to change it to see if that works. Can you help please
  • 1 more comment
  • Peter6 Sep 06, 2008
    I have renewed the element in the main oven after it blew, however I have no power, Can anyone tell me if and where the fuse is and how to get at it?
  • Anonymous Mar 16, 2014
    my newwave duel fuel cooker trips electric
  • Anonymous Mar 20, 2014
    trips the electric when switched on
    New Friend:
I have a gyroflo oven G90m and the fan not turning and the oven is over heating and tripping out can you get a replacing fan?.
Posted on Mar 28, 2017
This usually means an earth fault, probably a faulty element
Posted on Dec 18, 2007
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
Why does the cooker keep tripping the electric power?
loose wire,shorted switch?(You will receive an answer like this if,you did not include the make or model or serial number or
date of manufacture or complete problem and what needs to be done.)
Jun 08, 2015 | Ovens
My hotpiont cooker c358ewh keeps tripping the electric every time I turn cooker on. Everything else works. It started when I self cleaned my oven. Can you help please
It's tripping because to much amperage is going to it, this tripping is a safety to let you know you have a problem.
Feb 10, 2015 | Ovens
The heating element is shorting out and causing it to blow the fuse
Aug 25, 2014 | Ovens
Flavel milano e60 electric cooker
Element or switch is done. Try switching elements first to see if that is it....if not then the switch is gonzo. The switch works as a potentiometer allowing more or less electricity (current) through the element.
Dec 02, 2013 | Ovens
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 07, 2011 | Smeg Ovens
My cooker has been working fine until now. but everytime i switch the cooker on at the mains now it keeps tripping my electric for everything. please help?.
if its tripping the breaker you have a direct short ,, check the ends of the element for a burned wire , and replace as necessary and check this link for solutions
Jun 02, 2011 | Ovens
Hi, I have a creda colonial range cooker. Yesterday I was using the fan oven and it tripped a fuse in the main fusebok of our house. I reset the fuse and now the 2 oveens wont work. The lights come on and...
All electrical appliance has a safety fuse located somewhere in the interior, most of the time it can be replaced.
always unplug electricity before attempting to repair on any electrical appliance
Sep 13, 2017 | Creda Colonial 42352 23 in. Electric...
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
New World 60ECHDGm Electric Kitchen Range Logo
1,387 people viewed this question
Top New World Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
