Question about Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel will not shoot in AF mode
I have a Canon Rebel digital and it will not shoot in AF mode. It will focus when button is pressed down partially but when pressed down all the way nothing happens. It works in MF mode.
  • Anonymous Jan 07, 2008
    Hello i have the same problem, i am not sure the AF is as good as it could be, manual seems better and the camera will not shoot in any of the Auto Modes.
  • 169 Answers
The mirror is problem of your camera,it alway been close that why the sensor is functioning properly cause that sensor is working in af mode....check the post at the side of the mirror if not broken and the spring of the mirror if not dislocated....doing this you should removed the lens from the body......
Posted on Aug 26, 2007
SOURCE:
Hi there. i owned a Canon EOS 60D model camera. The problem is, its AF option is not working except Auto n 'C' modes. While i am trying to use it in M mode with AF, its not working but in auto mode an
Are you sure you did not put the AF/ MF switch in the wrong position? Although I don't think it would focus in Auto mode. In all other modes, are you sure you selected a (or more) focus point(s) in the centre of the frame?
When the selected focus point is on the side of the frame it won't focus on the parts you want it to focus. Then while pointing to the point you want the camera to focus, please press the shutter release button half and what till it focusses. Then press it the whole way down. Be aware the camera needs enough light to focus and certainly can't focus with a lens wit a min aperture of 6 or a larger number. On your 18-135 you can shoot at f16 because it will first focus on wide open and only close the aperture after you pressed the button.
Jan 27, 2015 | Canon EOS 60D Digital Camera
All of a sudden, my Canon Rebel SLR stopped focusing and I cannot depress the shutter button when on AF mode. I can press the shutter button on MF mode, but there is no focusing happening. Do you think...
Try this...remove the lens and fire off a few shots. Clean the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol. Re-attach the lens and try it.
Apr 13, 2011 | Canon Digital Rebel XSi Digital Camera
My auto focus will not work.
lens af unit gear is broken, or lens af saft if broken, or lens af flex is broken.
or could be camera sub mirror spring is come out from mirror unit.
take it to canon repaire centre to estimate
Jul 05, 2010 | Canon EOS Rebel XSi Digital Camera
Camera xsi rebel 12.5 megapixel won't focus with
Most entry level SLR cameras will struggle to focus in low light, especially with the kit lens. By rights the flash should popup and emit a flash pulse to help focus. This is called focus assist. You might have to consult the manual to check if this function is turned on or not.
Oct 09, 2009 | Canon EOS Rebel XSi Digital Camera
Auto focus does not work in creative modes
That is a custom function of the camera that can be change back to default with ease. While in one of the creative zones press the menu button and navigate to the 5th and final tab on the top right. 8f5da8f.jpg
This is the Setup menu 2. In this menu, select “Custom Functions (C. Fn)” . This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. 7528356.jpg
That should get your camera back to the expected auto focus with the shutter button.
Mar 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Flash pre-firing like mad?
It is your camera using the flash to assist in focusing, if it bothers you you can change it in your menus, I have a XTi so yours will differ slightly.
Switch your camera to "P" mode.
Press "Menu" button.
Go to setup menu 3
scroll down to "Custom Functions (C Fn.)"
Press "set".
press to the right until you find "AF - assist beam"
Press "set".
And press up or down.
Set to "Does not emit"
press "set"
Press "menu" button twice.
Mar 08, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
No AF point display indicator in Creative Zone modes.
In creative mode I would imagine that you are required to choose the focus point. Try the arrow buttons.
Jan 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Cannot preview shots in lcd with new Canon Rebel xs 1000d
There are two modes to the XS's Live View system, selectable via Custom Function 7. Live View is disabled by default, by the way, so you'll need to find this menu item in Settings Menu 2 to turn it on. The two options are called Quick and Live modes. Quick mode works as most Live View modes do, dropping the mirror when you press the AE-Lock button (marked with an asterisk) to use the conventional phase-detect autofocus system. This temporarily blacks out the Live View image, which makes it impossible to know that you're still framing the subject and holding your AF point in the proper place.
That's why they added the second mode, which they call Live, but is better described as contrast-detect autofocus. This works just like a digicam, reading the image from the imaging sensor while adjusting the lens for the setting that produces the most contrast in the image. A small square appears in the center of the image area, and you can move it around with the cross keys. Just like Quick mode, unfortunately, you have to press the AE-Lock button first until you hear the focus confirmation beep, then press the shutter button to fire. It's a little slower at times than phase-detect mode, but it gets the job done. Live mode is really better for tripod work, where you can place the AF area right where you want it and confirm focus onscreen.
Both modes offer the ability to zoom in on your live view, excellent for confirming focus before capture. Using the Magnify button just right of the AE-Lock button, you can zoom in 5x or 10x, then press the AE-Lock button to focus if you like; but of course you can't confirm framing in that mode.
Jan 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Manual focus points 40D
Try checking C.Fn III, 3: AF point selection method. Yours might still be on option 2.
0: Normal - Works by pressing the AF Point button and then the Multi-controller.
1: Multi-controller direct - Press the multi-controller to directly select an AF point (without first having to press the AF Point button). Pressing the AF button reinstates all AF points for auto AF point selection.
2: Quick Control Dial direct - turn the Quick Control Dial to select AF points. In this mode, AF points will not be displayed on the LCD panel.
Jul 18, 2008 | Canon EOS 40D Digital Camera
Canon Rebel xti - auto focus problem
AI should be focusing. You really can't change many settings when you are shooting in auto mode. Is the lens in AF mode?
I'm sure you have long since returned from vacation!
Hope this helps!
Dec 31, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
235 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
