Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet front load washer door trouble
I have the duet dryer stacked on the washer and have noticed the washer door is bending a bit outward at the to left side. Is this because of the pressure of stacking? I just purchased these 10 months ago. help.
I have stacked ours too, though after 5 years we have not had any issues with the pressure. I would suggest checking the screws holding the hinge in place as they may have loosened or been tightened with the door not properly lined up.
Posted on Oct 04, 2007
SOURCE:
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Do you have instruction how to replace the whirpool duet door seal (boot)? modal number is wfw9400sw01. ser#csu2405380
Hi
Please see this video link to replace the door seal on your washer---
Please post for further assistance. Hope this helps...
Daniel
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
DRYER PROBLEM
When the pads on the front wear, it will make noise when running. They can be replaced. There is one on the top and one on the bottom rim where the drum turns. You remove the front to access them by removing the screws on the top. Post your model number for diagrams. It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Mar 21, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Whirpool duet washer
This one is complicated, and could involve drain pump operation or pressure switch hose condition. Behind the bottom panel, there is a detailed troubleshooting guide, and goes into detail about possible solutions to this problem. The bottom panel has three small bolts (facing outward), remove them and the panel comes off, and the guide is in plastic, glued to the back of the panel. Hope this helps.
Dec 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can the Whirlpool Duets stack?
The simple, short answer is yes, the Whirlpool Duet washer and dryers can be stacked. You'll need to check with the Whirlpool folks to see if you'll need a stacking kit, or if they are ready to go with what you already have.
The key to stacking these Duet laundry pairs, is to have both the washer and dryer model numbers when you contact Whirlpool, so they can provide you with the stacking kit needed to mount the dryer on top of the washer. You can also check the Whirlpool web site to get a good idea of how much space is needed for a stacked set. Here's the link for the space checker, just look under the Guides and Tools on the left side and click on the Laundry Space Sizer to see what's needed.
http://www.whirlpool.com/catalog/category.jsp?cat=115
You can also call Whirlpool at (866) 698-2538 and speak to them about your particular washer and dryer.
Hope you find this Very Helpful and best regards!
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My clothes are stuck in my front loading whirlpool washer. How do I open the door manually
The following link explains how to open the door manually on a Whirpool Duet:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I looked for door switch kit and some descriptions say for stacking...i don't need that and have duet model 9200 in white. want both doors to open in opposite diections. do i need to buy kits?
ummm.. you can only reverse the door opening in oyour dryer, your washer CANNOT be switched it only opens to the left. the dryer can be switched and the "hine kit" if applicable, only contains a new peicw of trim to cover the exposed trim after revesing the door( the catches are on top and bottom no need to reverse them)
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Washer
I guess electric door lock just stacked. To prevent door breakage call to your local appliance repair company.
_______________________________________
http://www.allstarsappliance.com
Aug 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
298 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
